December maintenance updates: Nextcloud Hub 10 & Nextcloud Hub 25 Autumn
Originally published at: December maintenance updates: Nextcloud Hub 10 & Nextcloud Hub 25 Autumn - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 10 or Nextcloud Hub 25 Autumn, we strongly recommend you to update to version 31.0.12 and 32.0.3 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
  • Nextcloud Hub 10 (version 31.0.12)
  • Nextcloud Hub 25 Autumn (version 32.0.3)
Join the launch of the new Nextcloud Hub!
Join the Nextcloud Special Event, featuring the release of Nextcloud Hub 26 Winter, on 18 February and see how easy it can be regain data control.
Get your online seat now!
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
