DB connection failure after NC28 to NC29 upgrade
I did upgrade NC from v28 to v29 on docker. After the image upgrade, the application fails with “Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for db failed: Name or service not known”
The database is running according to the docker logs. This is the docker-compose.yaml that I use:
  nextclouddb:
    container_name: nextclouddb
    image: mariadb:10.6
    command: --skip-innodb-read-only-compressed --transaction-isolation=READ-COMMITTED --binlog-format=ROW
    restart: always
    volumes:
      - ./volumes/nextclouddb_mysql:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=xxxxx
      - MYSQL_PASSWORD=yyyyyy
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
    labels:
      - "com.centurylinklabs.watchtower.enable=true"
  nextcloud:
    image: nextcloud:29
    restart: always
    ports:
      - 127.0.0.1:8085:80
    depends_on:
      - nextclouddb
    links:
      - nextclouddb:db
    volumes:
      - ./volumes/nextcloud:/var/www/html
    environment:
      - MQSQL_HOST=db
    labels:
    • 29.0.10
    • Debian 11.11 x64
    • from docker image 29.0.10
    • from docker NC image 29.0.10
    • 8.2.26
    • Yes
    • After docker container update from NC28 to NC 29.0.10
    • Docker
See above
  1. Change docker image version from nextcloud:28 to nextcloud:29
  2. Recreate container
    "reqId": "wmZOS68FdTtAQqVVCx3u",
    "level": 3,
    "time": "2024-12-11T19:15:19+00:00",
    "remoteAddr": "217.247.97.12",
    "user": "--",
    "app": "core",
    "method": "GET",
    "url": "/index.php/204",
    "message": "Exception thrown: Doctrine\\DBAL\\Exception",
    "userAgent": "Mozilla/5.0 (Windows) mirall/3.15.0stable-Win64 (build 20241125) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)",
    "version": "28.0.13.1",
    "exception": {
        "Exception": "Doctrine\\DBAL\\Exception",
        "Message": "Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for db failed: Name or service not known",
        "Code": 2002,
        "Trace": [{
                "file": "/var/www/html/3rdparty/doctrine/dbal/src/Connection.php",
                "line": 453,
                "function": "connect",
                "class": "OC\\DB\\Connection",
                "type": "->",
                "args": []
                "line": 411,
                "function": "getDatabasePlatformVersion",
                "class": "Doctrine\\DBAL\\Connection",
                "type": "->",
                "args": []
                "line": 318,
                "function": "detectDatabasePlatform",
                "type": "->",
                "args": []
                "file": "/var/www/html/lib/private/DB/ConnectionAdapter.php",
                "line": 200,
                "function": "getDatabasePlatform",
                "type": "->",
                "args": []
                "file": "/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php",
                "line": 121,
                "class": "OC\\DB\\ConnectionAdapter",
                "type": "->",
                "args": []
                "file": "/var/www/html/lib/private/AppConfig.php",
                "line": 1239,
                "function": "expr",
                "class": "OC\\DB\\QueryBuilder\\QueryBuilder",
                "type": "->",
                "args": []
                "line": 264,
                "function": "loadConfig",
                "class": "OC\\AppConfig",
                "type": "->",
                "args": [false]
                "file": "/var/www/html/lib/private/legacy/OC_App.php",
                "line": 736,
                "function": "searchValues",
                "type": "->",
                "args": ["installed_version"]
                "file": "/var/www/html/lib/private/TemplateLayout.php",
                "line": 230,
                "function": "getAppVersions",
                "class": "OC_App",
                "type": "::",
                "args": []
                "file": "/var/www/html/lib/private/legacy/OC_Template.php",
                "line": 145,
                "function": "__construct",
                "class": "OC\\TemplateLayout",
                "type": "->",
                "args": ["error", ""]
                "file": "/var/www/html/lib/private/Template/Base.php",
                "line": 132,
                "function": "fetchPage",
                "class": "OC_Template",
                "type": "->",
                "args": []
                "line": 320,
                "function": "printPage",
                "class": "OC\\Template\\Base",
                "type": "->",
                "args": []
                "file": "/var/www/html/index.php",
                "line": 114,
                "function": "printExceptionErrorPage",
                "type": "::",
                "args": [{
                        "__class__": "Doctrine\\DBAL\\Exception"
                    }, 500]
        "File": "/var/www/html/lib/private/DB/Connection.php",
        "Line": 167,
        "CustomMessage": "Exception thrown: Doctrine\\DBAL\\Exception"
PASTE
PASTE HERE
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'instanceid' => '...',
  'passwordsalt' => '...',
  'secret' => '...',
    0 => '...',
  'version' => '28.0.13.1',
  'overwrite.cli.url' => '...',
  'dbname' => 'nextcloud',
  'dbhost' => 'db',
  'dbuser' => 'nextcloud',
  'dbpassword' => '...',
  'theme' => '',
  'loglevel' => 0,
  'mail_smtpmode' => 'smtp',
  'mail_domain' => '...',
  'mail_smtpauth' => 1,
  'mail_smtphost' => '...',
  'mail_smtpsecure' => 'ssl',
  'mail_smtpname' => '...',
  'mail_smtppassword' => '...',
  'mail_smtpport' => '465',
  'has_rebuilt_cache' => true,
this error indicates the system tries to access the DB at hosname “db”. which matches the config.php output:
from your compose file mariadb service runs as nextclouddb. my guess would be you change the service name of the database during the upgrade… please change it back or add an alias db to the service.
Thanks @wwe for the pointer! I did not change the database name during the upgrade - I double checked the content of config.php in the last 3 backups and the discrepancy between the composer name and the one in config.php was there before the upgrade too.
But for some reason after the upgrade, the
links:
      - nextclouddb:db
part of my docker compose file that creates the alias “db” seems to be ignored.
I now manually changed the dbhost to nextclouddb and that solved my issue but still leaves me puzzled why the link doesn’t work anymore.
I can not answer the question why this happened but links: directive is the very old deprecated way to connect multiple services (which happens automatically with the *-default network today. I’m not sure it also magically added an alias to service.. and likely some Docker upgrade finally completely removed the functionality..
for the reference if you want to create an DNS alias for the service in docker-compose just use “aliases”:
