I’m setting up my new Android 12 device (Pixel 6 Pro) and tried to use the DAVx5 integration. I have the Nextcloud app installed from the Google Play Store, and DAVx5 from F-Droid. I had this setup working on a previous device (Android 8.1).
Expected result: I click the “Sync Calendar and Contacts” option in settings, DAVx5 opens with the Nextcloud login flow.
Actual result: Clicking the “Sync Calendar and Contacts” option asks me to open either Google Play or F-Droid. Once in either app, I can open DAVx5 from there, but with no Nextcloud login flow, just the normal start screen.
Any advice?
