Ich habe gerade genau das gleiche Problem, gleiche Fehlermeldung von DavDroid, allerdings Android 7.1, NC 12 und Apache2 - Apache2 kennt diese Einstellungen von nginx nicht, ich habe ganz /etc danach gegrept, gibts nicht bei mir.
Noch jemand eine Idee? Hier die log von DAVdroid:
--- BEGIN DEBUG INFO ---
LOGS:
2017-11-22 11:09:35 433 [ui.setup.DavResourceFinder] Finding initial carddav service configuration
2017-11-22 11:09:35 433 [ui.setup.DavResourceFinder] Checking user-given URL: https://SERVER.de/cloud/
2017-11-22 11:09:35 433 [HttpClient] --> PROPFIND https://SERVER.de/cloud/
2017-11-22 11:09:35 433 [HttpClient] Content-Type: application/xml; charset=utf-8
2017-11-22 11:09:35 433 [HttpClient] Content-Length: 290
2017-11-22 11:09:35 433 [HttpClient] Depth: 0
2017-11-22 11:09:35 433 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><CARD:addressbook-description /><CARD:addressbook-home-set />
2017-11-22 11:09:35 433 [HttpClient] --> END PROPFIND (290-byte body)
2017-11-22 11:09:36 433 [HttpClient] <-- 405 Method Not Allowed https://SERVER.de/cloud/ (235ms)
2017-11-22 11:09:36 433 [HttpClient] Date: Wed, 22 Nov 2017 10:09:37 GMT
2017-11-22 11:09:36 433 [HttpClient] Server: Apache
2017-11-22 11:09:36 433 [HttpClient] Strict-Transport-Security: max-age=15552000
2017-11-22 11:09:36 433 [HttpClient] Set-Cookie: oc4fd360fe32=tvpiprtupddt4unedg13fue5l3; path=/cloud; HttpOnly
2017-11-22 11:09:36 433 [HttpClient] Expires: Thu, 19 Nov 1981 08:52:00 GMT
2017-11-22 11:09:36 433 [HttpClient] Cache-Control: no-store, no-cache, must-revalidate
2017-11-22 11:09:36 433 [HttpClient] Pragma: no-cache
2017-11-22 11:09:36 433 [HttpClient] Set-Cookie: oc_sessionPassphrase=41G0hEyxZVo8wS8am38pXhRnxsg3yTlgPRvrDr2%2BTfAIXmQykn95dydtK7vh9HBVnIW%2FOFLT3K3LQafrN3tXPtyE2fZFFitnhYpN2BNUhwwKkPpbQu%2FbBbnqnUjOsLWg; path=/cloud; secure; HttpOnly
2017-11-22 11:09:36 433 [HttpClient] Content-Security-Policy: default-src âselfâ; script-src âselfâ âunsafe-evalâ ânonce-ZUtIZFQ0ZzRwc0dyeFdmNkpXOXpTMUxQaGRvb2xKYUcwMnNZV2REWmc4Yz06RWM3ckpQQnQvL0RqOUNPOUZUMEZQd2VPOG94bDFkbmhvUWQvTEx5VndJbz0=â; style-src âselfâ âunsafe-inlineâ; frame-src *; img-src * data: blob:; font-src âselfâ data:; media-src *; connect-src *; object-src ânoneâ; base-uri âselfâ;
2017-11-22 11:09:36 433 [HttpClient] X-Frame-Options: SAMEORIGIN
2017-11-22 11:09:36 433 [HttpClient] Set-Cookie: nc_sameSiteCookielax=true; path=/cloud; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
2017-11-22 11:09:36 433 [HttpClient] Set-Cookie: nc_sameSiteCookiestrict=true; path=/cloud; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
2017-11-22 11:09:36 433 [HttpClient] Set-Cookie: oc4fd360fe32=3cb7ujiuq57v6pbnu880angic2; path=/cloud; secure; HttpOnly
2017-11-22 11:09:36 433 [HttpClient] Status: 405 Method Not Allowed
2017-11-22 11:09:36 433 [HttpClient] X-Content-Type-Options: nosniff
2017-11-22 11:09:36 433 [HttpClient] X-XSS-Protection: 1; mode=block
2017-11-22 11:09:36 433 [HttpClient] X-Robots-Tag: none
2017-11-22 11:09:36 433 [HttpClient] X-Download-Options: noopen
2017-11-22 11:09:36 433 [HttpClient] X-Permitted-Cross-Domain-Policies: none
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 0
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=100
2017-11-22 11:09:36 433 [HttpClient] Connection: Keep-Alive
2017-11-22 11:09:36 433 [HttpClient] Content-Type: text/html; charset=UTF-8
2017-11-22 11:09:36 433 [HttpClient] <-- END HTTP (0-byte body)
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] PROPFIND/OPTIONS on user-given URL failed
EXCEPTION at.bitfire.dav4android.exception.HttpException: 405 Method Not Allowed
at at.bitfire.dav4android.DavResource.checkStatus(DavResource.kt:331)
at at.bitfire.dav4android.DavResource.checkStatus(DavResource.kt:295)
at at.bitfire.dav4android.DavResource.propfind(DavResource.kt:271)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:166)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:101)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:73)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$ServerConfigurationLoader.loadInBackground(DetectConfigurationFragment.kt:131)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$ServerConfigurationLoader.loadInBackground(DetectConfigurationFragment.kt:112)
at android.content.AsyncTaskLoader.onLoadInBackground(AsyncTaskLoader.java:312)
at android.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:69)
at android.content.AsyncTaskLoader$LoadTask.doInBackground(AsyncTaskLoader.java:66)
at android.os.AsyncTask$2.call(AsyncTask.java:305)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
at java.lang.Thread.run(Thread.java:761)
2017-11-22 11:09:36 433 [HttpClient] --> PROPFIND https://SERVER.de/.well-known/carddav
2017-11-22 11:09:36 433 [HttpClient] Content-Type: application/xml; charset=utf-8
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 198
2017-11-22 11:09:36 433 [HttpClient] Depth: 0
2017-11-22 11:09:36 433 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?>
2017-11-22 11:09:36 433 [HttpClient] --> END PROPFIND (198-byte body)
2017-11-22 11:09:36 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/.well-known/carddav (58ms)
2017-11-22 11:09:36 433 [HttpClient] Date: Wed, 22 Nov 2017 10:09:38 GMT
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 228
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=99
2017-11-22 11:09:36 433 [HttpClient] Content-Type: text/html; charset=iso-8859-1
403 Forbidden
Forbidden
You don't have permission to access /.well-known/carddav
on this server.
2017-11-22 11:09:36 433 [HttpClient] <-- END HTTP (228-byte body)
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Well-known URL detection failed
EXCEPTION at.bitfire.dav4android.exception.HttpException: 403 Forbidden
at at.bitfire.davdroid.ui.setup.DavResourceFinder.getCurrentUserPrincipal(DavResourceFinder.kt:352)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:105)
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] No principal found at user-given URL, trying to discover
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Looking up SRV records for _carddavs._tcp.SERVER.de
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Didnât find carddav service, trying at https://SERVER.de:443
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Trying to determine principal from initial context path=https://SERVER.de/.well-known/carddav
2017-11-22 11:09:36 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/.well-known/carddav (74ms)
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=98
403 Forbidden
Forbidden
on this server.
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] No resource found
at at.bitfire.davdroid.ui.setup.DavResourceFinder.discoverPrincipalUrl(DavResourceFinder.kt:334)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:123)
2017-11-22 11:09:36 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/ (73ms)
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 209
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=97
403 Forbidden
Forbidden
on this server.
2017-11-22 11:09:36 433 [HttpClient] <-- END HTTP (209-byte body)
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Finding initial caldav service configuration
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Checking user-given URL: https://SERVER.de/cloud/
2017-11-22 11:09:36 433 [HttpClient] --> PROPFIND https://SERVER.de/cloud/
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 435
2017-11-22 11:09:36 433 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><n0:calendar-color xmlns:n0=âhttp://apple.com/ns/ical/â /><CAL:calendar-description /><CAL:calendar-timezone /><CAL:supported-calendar-component-set /><CAL:calendar-home-set />
2017-11-22 11:09:36 433 [HttpClient] --> END PROPFIND (435-byte body)
2017-11-22 11:09:36 433 [HttpClient] <-- 405 Method Not Allowed https://SERVER.de/cloud/ (90ms)
2017-11-22 11:09:36 433 [HttpClient] Content-Security-Policy: default-src âselfâ; script-src âselfâ âunsafe-evalâ ânonce-RHNpT2d6YndLUy9wR1hYS0NGaHR6QnZDRG5tTEd6VzNMRTZmYkdCY25kRT06WjZlNDZFNmxjQjZoS0RHTk9Bb2J1RTZEZVMvR1duclFYaUw0R1F3UTNwdz0=â; style-src âselfâ âunsafe-inlineâ; frame-src *; img-src * data: blob:; font-src âselfâ data:; media-src *; connect-src *; object-src ânoneâ; base-uri âselfâ;
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=96
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:174)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:74)
2017-11-22 11:09:36 433 [HttpClient] --> PROPFIND https://SERVER.de/.well-known/caldav
2017-11-22 11:09:36 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/.well-known/caldav (59ms)
2017-11-22 11:09:36 433 [HttpClient] Content-Length: 227
2017-11-22 11:09:36 433 [HttpClient] Keep-Alive: timeout=5, max=95
403 Forbidden
Forbidden
You don't have permission to access /.well-known/caldav
on this server.
2017-11-22 11:09:36 433 [HttpClient] <-- END HTTP (227-byte body)
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Looking up SRV records for _caldavs._tcp.SERVER.de
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Didnât find caldav service, trying at https://SERVER.de:443
2017-11-22 11:09:36 433 [ui.setup.DavResourceFinder] Trying to determine principal from initial context path=https://SERVER.de/.well-known/caldav
2017-11-22 11:09:37 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/.well-known/caldav (75ms)
2017-11-22 11:09:37 433 [HttpClient] Date: Wed, 22 Nov 2017 10:09:38 GMT
2017-11-22 11:09:37 433 [HttpClient] Server: Apache
2017-11-22 11:09:37 433 [HttpClient] Strict-Transport-Security: max-age=15552000
2017-11-22 11:09:37 433 [HttpClient] Content-Length: 227
2017-11-22 11:09:37 433 [HttpClient] Keep-Alive: timeout=5, max=94
2017-11-22 11:09:37 433 [HttpClient] Connection: Keep-Alive
2017-11-22 11:09:37 433 [HttpClient] Content-Type: text/html; charset=iso-8859-1
403 Forbidden
Forbidden
on this server.
2017-11-22 11:09:37 433 [HttpClient] <-- END HTTP (227-byte body)
2017-11-22 11:09:37 433 [ui.setup.DavResourceFinder] No resource found
2017-11-22 11:09:37 433 [ui.setup.DavResourceFinder] Trying to determine principal from initial context path=https://SERVER.de/
2017-11-22 11:09:37 433 [HttpClient] --> PROPFIND https://SERVER.de/
2017-11-22 11:09:37 433 [HttpClient] Content-Type: application/xml; charset=utf-8
2017-11-22 11:09:37 433 [HttpClient] Content-Length: 198
2017-11-22 11:09:37 433 [HttpClient] Depth: 0
2017-11-22 11:09:37 433 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?>
2017-11-22 11:09:37 433 [HttpClient] --> END PROPFIND (198-byte body)
2017-11-22 11:09:37 433 [HttpClient] <-- 403 Forbidden https://SERVER.de/ (52ms)
2017-11-22 11:09:37 433 [HttpClient] Content-Length: 209
2017-11-22 11:09:37 433 [HttpClient] Keep-Alive: timeout=5, max=93
403 Forbidden
Forbidden
on this server.
2017-11-22 11:09:37 433 [HttpClient] <-- END HTTP (209-byte body)
SOFTWARE INFORMATION
Package: at.bitfire.davdroid
Version: 1.9.3-gplay (189) from 12.11.2017
Installed from: com.android.vending
JB Workaround installed: no
CONNECTIVITY (at the moment)
Active connection: WiFi, CONNECTED
CONFIGURATION
Power saving disabled: no
android.permission.READ_CONTACTS permission: denied
android.permission.WRITE_CONTACTS permission: denied
android.permission.READ_CALENDAR permission: denied
android.permission.WRITE_CALENDAR permission: denied
org.dmfs.permission.READ_TASKS permission: denied
org.dmfs.permission.WRITE_TASKS permission: denied
System-wide synchronization: automatically
SQLITE DUMP
android_metadata
| locale |
| de_DE |
services
| _id | accountName | service | principal |
sqlite_sequence
| name | seq |
homesets
| _id | serviceID | url |
collections
| _id | serviceID | type | url | readOnly | displayName | description | color | timezone | supportsVEVENT | supportsVTODO | source | sync |
SYSTEM INFORMATION
Android version: 7.1.2 (lineage_hammerhead-userdebug 7.1.2 NJH47F 77433d9635)
Device: LGE Nexus 5 (hammerhead)
â END DEBUG INFO â
