Datenbank zu klein? General error: 1709 Index column size too large. The maximum column size is 767 bytes
Seit einigen Tagen meckert meine NC rum das in der Datenbank einige Indizes fehler wĂŒrden:
  • Fehlender Index "properties_pathonly_index" in der Tabelle "oc_properties".
  • Fehlender Index "job_lastcheck_reserved" in der Tabelle "oc_jobs".
Wie angegeben einmal sudo -u www-data php occ db:add-missing-indices versucht und dann kommt:
Check indices of the share table.
Check indices of the filecache table.
Check indices of the twofactor_providers table.
Check indices of the login_flow_v2 table.
Check indices of the whats_new table.
Check indices of the cards table.
Check indices of the cards_properties table.
Check indices of the calendarobjects_props table.
Check indices of the schedulingobjects table.
Check indices of the oc_properties table.
Adding properties_pathonly_index index to the oc_properties table, this can take some time
In ExceptionConverter.php line 114:
  • An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1709 Index column size too large. The maximum column size is 767 bytes
In Exception.php line 26:
  • SQLSTATE[HY000]: General error: 1709 Index column size too large. The maximum column size is 767 bytes
In Connection.php line 82:
ein Versuch mit `sudo -u www-data php occ maintenance:repair` brachte keine Besserung.
  • Repair MySQL collation
    • All tables already have the correct collation → nothing to do
  • Repair mime types
  • Clean tags and favorites
    • 0 tags of deleted users have been removed.
    • 0 tags for delete files have been removed.
    • 0 tag entries for deleted tags have been removed.
    • 0 tags with no entries have been removed.
  • Repair invalid shares
  • Move .step file of updater to backup location
  • Add move avatar background job
    • Repair step already executed
  • Add preview cleanup background jobs
  • Fix potential broken mount points
    • No mounts updated
  • Repair language codes
  • Install new core bundle components
  • Add log rotate job
  • Clear frontend caches
    • Image cache cleared
    • SCSS cache cleared
    • JS cache cleared
  • Clear every generated avatar on major updates
  • Add preview background cleanup job
  • Queue a one-time job to cleanup old backups of the updater
  • Cleanup invalid photocache files for carddav
  • Add background job to cleanup login flow v2 tokens
  • Remove potentially over exposing share links
    • No need to remove link shares.
  • Clear access cache of projects
  • Reset generated avatar flag
  • Keep legacy encryption enabled
  • Check encryption key format
  • Remove old dashboard app config data
  • Add job to cleanup the bruteforce entries
  • Queue a one-time job to check for user uploaded certificates
  • Repair DAV shares
  • Add background job to set the lookup server share state for users
  • Update name of the stored view
  • Upgrading Circles App
  • Fix component of birthday calendars
    • 0 birthday calendars updated.
  • Regenerating birthday calendars to use new icons and fix old birthday events without year
  • Fix broken values of calendar objects
    0 [->--------------------------]
  • Registering building of calendar search index as background job
  • Register building of social profile search index as background job
  • Registering background jobs to update cache for webcal calendars
    • Added 0 background jobs to update webcal calendars
  • Registering building of calendar reminder index as background job
  • Clean up orphan event and contact data
    • 0 events without a calendar have been cleaned up
    • 0 properties without an events have been cleaned up
    • 0 changes without a calendar have been cleaned up
    • 0 cached events without a calendar subscription have been cleaned up
    • 0 changes without a calendar subscription have been cleaned up
    • 0 contacts without an addressbook have been cleaned up
    • 0 properties without a contact have been cleaned up
    • 0 changes without an addressbook have been cleaned up
  • Remove activity entries of private events
    • Removed 0 activity entries
  • Clean up old calendar subscriptions from deleted users that were not cleaned-up
    0 [----->----------------------]
    • 0 calendar subscriptions without an user have been cleaned up
  • Rebuild font library
  • Fix the share type of guest shares when migrating from ownCloud
  • Copy the share password into the dedicated column
  • Set existing shares as accepted
  • Set binary permissions
  • Update OAuth token expiration times
  • onlyoffice
  • Create help command
  • Invalidate access cache for projects conversation provider
    • Invalidation not required
  • Cache the user display names
  • Switches from default updater server to the customer one if a valid subscription is available
  • Send an admin notification if monthly report is disabled
  • Add background job to check for backup codes
  • Populating added database structures for workflows
Ich hab auch versucht in der Datenbank an sich rumzupfuschen (fĂŒr einen absoluter DB-Laie wie mich ist rumpfuschen noch sehr euphemistisch ausgedrĂŒckt) wie z.B. hier beschrieben, aber das war alles vorher schon so.
An anderer Stelle liest sich man solle innodb_default_row_format=dynamic hinzufĂŒgen. Ich weis nur nicht wo.
HinzufĂŒgen weiterer Zeilen in die /etc/mysql/my.cnf wie in Hier beschrieben hilft auch nicht.
Meine NC lĂ€uft als VM auf einem NAS, ich habe nach der Anleitung von Decatec installiert und das ganze ist ĂŒber eine Subdomain eines DynDNS Service zu erreichen. Die NC-Apps und die Linux-Pakete sind alle auf dem Stand was gerade aktuell ist.
APP: Kann man hier im Forum Text einfĂ€rben? Und wenn “Ja.” wie?
Huhu, nicht ganz genau der Fehler, aber eventuell hilfts: https://github.com/nextcloud/server/issues/23369#issuecomment-707313974
Habe leider genau das selbe Problem und benötige Hilfe.
Hatte gedacht die utf8-mb4 umstellung damals hÀtte evtl nicht richtig funktioniert, aber leider hat es wohl.
Auch eventuelle Änderungen in der cnf der mariadb10.3.32 halfen nix, und ein Freund mit Ă€hnlicher nextcloud hat diese Änderungen in der cnf der mariadb auch nicht die nextcloud empfiehlt
Hatte nach dem Update auf 23.0.2 das gleiche Problem.
Lösung: ALTER TABLE oc_properties ROW_FORMAT=DYNAMIC;
In welche *.cnf sollte man dies eintragen?
Das musst du als SQL-Statement ausfĂŒhren, es verĂ€ndert das row-Format der Tabelle oc_properties. Also so heißt die Tabelle bei mir, kann sein, dass sie bei dir einen anderen PrĂ€fix hat. Den Namen findest du in der Fehlermeldung in der Nextcloud-OberflĂ€che “Fehlender Index “properties_pathonly_index” in der Tabelle “oc_properties”.”
Das Statement musst du direkt auf dem MySQL-Server absetzen bspw. in phpmyadmin oder direkt an der Konsole.
 und danach natĂŒrlich nochmals occ db:add-missing-indices ausfĂŒhren
Danke, ollihart!
FĂŒr die die es auch betrifft und genau so unwissend sind wie ich:
  1. mysql -u root -p (mit Passwort bestÀtigen
 sofern man es noch weis)
  2. MariaDB [(none)]> use nextcloud_db; (oder eben die eigene DB nehmen, “show databases;” hilft)
  3. hier nun ALTER TABLE oc_properties ROW_FORMAT=DYNAMIC; nutzen
  4. exit
  5. cd /Pfad/zu/occ/
  6. occ db:add-missing-indices ausfĂŒhren
  7. freuen!
noch eine kleine Anmerkung, vor allem fĂŒr die, die das root-Kennwort des MySQL-Servers nicht (mehr) kennen.
Nextcloud nutzt fĂŒr seine MySQL-GeschĂ€fte einen eigenen Mysql-Nutzer - so, wie es auch sein soll. Dieses Nutzerkonto findet man in der nextcloud config.php (im Unterordner config). Dort findet man dbuser und dbpassword - und auch den Datenbanknamen (dbname)
Dieser Nutzer hat alle nötigen Rechte. Nextcloud selber nutzt auch (nur) diesen Nutzer fĂŒr den Zugriff auf seine MySQL-Datenbank. Hat man diese Zugangsdaten, startet man die Mysql-Konsole mit
mysql <dbname> -u<dbuser> -p<dbpassword>
Schritt 2 von “reihner_zu_fall” entfĂ€llt dann, weil man sich mit dem Konsolenstart direkt mit der entsprechenden Datenbank verbindet.
Super vielen Dank. Dies hat funktioniert!
Vielen Dank, hat mir auch geholfen :slight_smile:
