Datadir not there
    • 10.7.0
    • Debian
    • Latest Docker container
    • Yes
    • Today
    • Docker
    • Yes, cloudflare tunnel
Basically my [nextcloud-aio-nextcloud] container fails to start, which causes some sub container to not start as well.
  1. Start all containers
Connection to nextcloud-aio-database (172.18.0.3) 5432 port [tcp/postgresql] succeeded!
              now
 2025-03-23 17:12:05.067262+00
(1 row)
+ '[' -n '' ']'
+ set +x
Connection to nextcloud-aio-redis (172.18.0.4) 6379 port [tcp/redis] succeeded!
Appdata is not present. Did you maybe change the datadir after the initial Nextcloud installation? This is not supported!
See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
If you adjusted the datadir to be located on an external drive, make sure that the drive is still mounted!
In the datadir was found:
total 4
drwxr-x--- 2 www-data root   40 Mar 23 17:12 .
drwxr-xr-x 1 root     root 4096 Mar 23 16:47 ..
services:
  app:
    restart: unless-stopped
    volumes:
      - //var/run/docker.sock:/var/run/docker.sock:ro
    ports:
      - 80:80
      - 8080:8080
      - 8443:8443
    environment:
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
      - NEXTCLOUD_DATADIR=/run/desktop/mnt/host/d/ncdata
  tunnel:
    image: cloudflare/cloudflared:latest
    command: tunnel run
    environment:
      - TUNNEL_TOKEN=
volumes:
Additional info:
I did not change the directory or change drives or anything, it was working before and now just stopped working.
this doesn’t sound right - I bet you don’t have /run/desktop.. in your AIO container. as you mount the mastercontainer volume into /mnt/docker-aio-config likely this is the value you want to use there…
Please familiarize yourself with Docker volumes
Hi, @wwe, please check GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.. This is actually the correct apporach because the sibling nextcloud-aio-nextcloud container will have the chosen directory mounted as volume.
OMG I will never understand this tool! It’s really way too complicated for me.
but still wrong:
when the system is running
So like what do I need to change now, in order that it mounts the right volume?
