Nextcloud version: 28.0.1
Operating system and version: FreeBSD 13.1-RELEASE-p9 (Jail on a TrueNAS System)
Apache or nginx version: nginx 1.24.0
PHP version: 8.1.25
Update: Performed by Webupdater (previously used for 2 minor updates without issues)
I updated today from Nextcloud 27 to 28 and parts of the webinterface (e.g. viewing of the Logs or the viewing of recent activities) aren’t working anymore and there are errors generated in the log.
The general file system seems to work and the sync is currently not broken
There seems to be a problem with the database connection but I am not able to find the reason.
I can normally connect to the mysql databse with username and passwort and the database “nextcloud” is there.
Is this the first time you’ve seen this error? :Y
The issue is always there. A restart of the system doesn’t help.
The output of your Nextcloud log in Admin > Logging: (Not available, added the last lines of nextcloud.log)
{"reqId":"bP3vJD7XcmHiHOy4CfiG","level":2,"time":"2024-01-19T18:20:48+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Error while generating metadata for fileid 2852","userAgent":"--","version":"28.0.1.1","exception":{"Exception":"RedisException","Message":"Redis server localhost:6379 went away","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/Memcache/Redis.php","line":137,"function":"incrBy","class":"Redis","type":"->","args":["8ba50b7840db7c9315f02d11f89d8c3e/lockfiles/72f950a35a2d8623cf263149f9b48978",1]},{"file":"/usr/local/www/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":61,"function":"inc","class":"OC\\Memcache\\Redis","type":"->","args":["files/72f950a35a2d8623cf263149f9b48978"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Storage/Common.php","line":765,"function":"acquireLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->","args":["files/72f950a35a2d8623cf263149f9b48978",1,"home::ncadmin::files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":607,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->","args":["files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",1,["OC\\Lock\\MemcacheLockingProvider"]]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":607,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":["files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",1,["OC\\Lock\\MemcacheLockingProvider"]]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":1938,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":["files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",1,["OC\\Lock\\MemcacheLockingProvider"]]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":2048,"function":"lockPath","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",1,false]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":1141,"function":"lockFile","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",1]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":987,"function":"basicOperation","class":"OC\\Files\\View","type":"->","args":["fopen","/ncadmin/files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg",["read"],"r"]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Node/File.php","line":116,"function":"fopen","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191018_Bauwagen/Karl Rehfu\u00df.jpg","r"]},{"file":"/usr/local/www/nextcloud/apps/photos/lib/Listener/ExifMetadataProvider.php","line":63,"function":"fopen","class":"OC\\Files\\Node\\File","type":"->","args":["rb"]},{"file":"/usr/local/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":86,"function":"handle","class":"OCA\\Photos\\Listener\\ExifMetadataProvider","type":"->","args":[["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":230,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->","args":[["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"],"OCP\\FilesMetadata\\Event\\MetadataLiveEvent",["Symfony\\Component\\EventDispatcher\\EventDispatcher"]]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":59,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[[["Closure"],["Closure"],["Closure"],["Closure"]],"OCP\\FilesMetadata\\Event\\MetadataLiveEvent",["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]]},{"file":"/usr/local/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":94,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->","args":[["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"],"OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]},{"file":"/usr/local/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":106,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":["OCP\\FilesMetadata\\Event\\MetadataLiveEvent",["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/FilesMetadataManager.php","line":115,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->","args":[["OCP\\FilesMetadata\\Event\\MetadataLiveEvent"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":110,"function":"refreshMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":[["OC\\Files\\Node\\File"],3]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/lib/private/Memcache/Redis.php","Line":137,"message":"Error while generating metadata for fileid 2852","exception":{},"CustomMessage":"Error while generating metadata for fileid 2852"}}
{"reqId":"bP3vJD7XcmHiHOy4CfiG","level":2,"time":"2024-01-19T18:20:48+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Error while generating metadata for fileid 1446","userAgent":"--","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\PDOException","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":"HY000","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":137,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\PDOException","type":"::","args":[["PDOException",["HY000",2006,"MySQL server has gone away"]]]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1516,"function":"rollBack","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":162,"function":"rollBack","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/Service/IndexRequestService.php","line":83,"function":"rollBack","class":"OC\\DB\\ConnectionAdapter","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/FilesMetadataManager.php","line":199,"function":"updateIndex","class":"OC\\FilesMetadata\\Service\\IndexRequestService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/FilesMetadataManager.php","line":116,"function":"saveMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":110,"function":"refreshMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":[["OC\\Files\\Node\\File"],3]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/PDOException.php","Line":20,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":"HY000","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":135,"function":"rollBack","class":"PDO","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1516,"function":"rollBack","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":162,"function":"rollBack","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/Service/IndexRequestService.php","line":83,"function":"rollBack","class":"OC\\DB\\ConnectionAdapter","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/FilesMetadataManager.php","line":199,"function":"updateIndex","class":"OC\\FilesMetadata\\Service\\IndexRequestService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/FilesMetadata/FilesMetadataManager.php","line":116,"function":"saveMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":110,"function":"refreshMetadata","class":"OC\\FilesMetadata\\FilesMetadataManager","type":"->","args":[["OC\\Files\\Node\\File"],3]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","Line":135},"message":"Error while generating metadata for fileid 1446","exception":{"errorInfo":["HY000",2006,"MySQL server has gone away"]},"CustomMessage":"Error while generating metadata for fileid 1446"}}
{"reqId":"bP3vJD7XcmHiHOy4CfiG","level":3,"time":"2024-01-19T18:20:48+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job (class: OC\\Core\\BackgroundJobs\\GenerateMetadataJob, arguments: )","userAgent":"--","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\ConnectionLost","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":2006,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1938,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1880,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1105,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],"SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = ? ORDER BY `name` ASC",[9962],[1]]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = ? ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = :dcValue1 ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":248,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":1457,"function":"getFolderContentsById","class":"OC\\Files\\Cache\\Cache","type":"->","args":[9962]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Node/Folder.php","line":102,"function":"getDirectoryContent","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191114_VU_Stockach","",["OC\\Files\\FileInfo"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":101,"function":"getDirectoryListing","class":"OC\\Files\\Node\\Folder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":104,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":2006,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[["PDOException",["HY000",2006,"MySQL server has gone away"]]]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1098,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = ? ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = :dcValue1 ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":248,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":1457,"function":"getFolderContentsById","class":"OC\\Files\\Cache\\Cache","type":"->","args":[9962]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Node/Folder.php","line":102,"function":"getDirectoryContent","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191114_VU_Stockach","",["OC\\Files\\FileInfo"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":101,"function":"getDirectoryListing","class":"OC\\Files\\Node\\Folder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":"HY000","Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1098,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = ? ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `filecache`.`name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `filecache`.`permissions`, `checksum`, `unencrypted_size`, `metadata_etag`, `creation_time`, `upload_time`, `meta`.`json` AS `meta_json`, `meta`.`sync_token` AS `meta_sync_token` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` LEFT JOIN `oc_files_metadata` `meta` ON `filecache`.`fileid` = `meta`.`file_id` WHERE `filecache`.`parent` = :dcValue1 ORDER BY `name` ASC",[9962],[1],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Cache/Cache.php","line":248,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/Files/View.php","line":1457,"function":"getFolderContentsById","class":"OC\\Files\\Cache\\Cache","type":"->","args":[9962]},{"file":"/usr/local/www/nextcloud/lib/private/Files/Node/Folder.php","line":102,"function":"getDirectoryContent","class":"OC\\Files\\View","type":"->","args":["/ncadmin/files/Bilder/2019/Einsatzbilder/191114_VU_Stockach","",["OC\\Files\\FileInfo"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":101,"function":"getDirectoryListing","class":"OC\\Files\\Node\\Folder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":103,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\Folder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":92,"function":"scanFolder","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[["OC\\Files\\Node\\LazyUserFolder"]]},{"file":"/usr/local/www/nextcloud/core/BackgroundJobs/GenerateMetadataJob.php","line":83,"function":"scanFilesForUser","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":["ncadmin"]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/Job.php","line":81,"function":"run","class":"OC\\Core\\BackgroundJobs\\GenerateMetadataJob","type":"->","args":[null]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":102,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/lib/public/BackgroundJob/TimedJob.php","line":92,"function":"start","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":152,"function":"execute","class":"OCP\\BackgroundJob\\TimedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"],["OC\\Log"]]}],"File":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}},"message":"Error while running background job (class: OC\\Core\\BackgroundJobs\\GenerateMetadataJob, arguments: )","exception":{},"CustomMessage":"Error while running background job (class: OC\\Core\\BackgroundJobs\\GenerateMetadataJob, arguments: )"}}
{"reqId":"bP3vJD7XcmHiHOy4CfiG","level":3,"time":"2024-01-19T18:20:48+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Exception thrown: Doctrine\\DBAL\\Exception","userAgent":"--","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","Code":2002,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1654,"function":"connect","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":865,"function":"getWrappedConnection","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/Expression/ExpressionBuilder.php","line":321,"function":"quote","class":"Doctrine\\DBAL\\Connection","type":"->","args":[0,1]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/ExpressionBuilder/ExpressionBuilder.php","line":422,"function":"literal","class":"Doctrine\\DBAL\\Query\\Expression\\ExpressionBuilder","type":"->","args":[0,1]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":366,"function":"literal","class":"OC\\DB\\QueryBuilder\\ExpressionBuilder\\ExpressionBuilder","type":"->","args":[0,1]},{"file":"/usr/local/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":356,"function":"unlockJob","class":"OC\\BackgroundJob\\JobList","type":"->","args":[["OC\\Core\\BackgroundJobs\\GenerateMetadataJob"]]},{"file":"/usr/local/www/nextcloud/cron.php","line":158,"function":"setLastJob","class":"OC\\BackgroundJob\\JobList","type":"->","args":[["OC\\Core\\BackgroundJobs\\GenerateMetadataJob"]]}],"File":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","Line":139,"CustomMessage":"Exception thrown: Doctrine\\DBAL\\Exception"}}
{"reqId":"0VlnnjifGrUflwgopUkG","level":3,"time":"2024-01-19T18:26:25+00:00","remoteAddr":"46.5.221.2","user":"--","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications","message":"Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory at /usr/local/www/nextcloud/lib/private/DB/Connection.php#139","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"Lwn6hHXQ0D3oujt7QuCn","level":3,"time":"2024-01-19T18:26:29+00:00","remoteAddr":"46.5.221.2","user":"--","app":"index","method":"GET","url":"/index.php/204","message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","Code":2002,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1654,"function":"connect","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1081,"function":"getWrappedConnection","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/usr/local/www/nextcloud/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/usr/local/www/nextcloud/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/usr/local/www/nextcloud/index.php","line":37,"args":["/usr/local/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","Line":139,"message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","exception":{},"CustomMessage":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory"}}
{"reqId":"Lwn6hHXQ0D3oujt7QuCn","level":3,"time":"2024-01-19T18:26:35+00:00","remoteAddr":"46.5.221.2","user":"--","app":"core","method":"GET","url":"/index.php/204","message":"Exception thrown: Doctrine\\DBAL\\Exception","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","Code":2002,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1654,"function":"connect","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1081,"function":"getWrappedConnection","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/usr/local/www/nextcloud/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/usr/local/www/nextcloud/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/usr/local/www/nextcloud/index.php","line":37,"args":["/usr/local/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","Line":139,"CustomMessage":"Exception thrown: Doctrine\\DBAL\\Exception"}}
{"reqId":"Lwn6hHXQ0D3oujt7QuCn","level":3,"time":"2024-01-19T18:26:35+00:00","remoteAddr":"46.5.221.2","user":"--","app":"core","method":"GET","url":"/index.php/204","message":"Exception thrown: Doctrine\\DBAL\\Exception","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception","Message":"Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory","Code":2002,"Trace":[{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1654,"function":"connect","class":"OC\\DB\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1081,"function":"getWrappedConnection","class":"Doctrine\\DBAL\\Connection","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":341,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/usr/local/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":734,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/usr/local/www/nextcloud/lib/private/TemplateLayout.php","line":236,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"/usr/local/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Template.php","line":291,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/index.php","line":104,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["Doctrine\\DBAL\\Exception"],500]}],"File":"/usr/local/www/nextcloud/lib/private/DB/Connection.php","Line":139,"CustomMessage":"Exception thrown: Doctrine\\DBAL\\Exception"}}
{"reqId":"SxhrQizw28dtd1JyYxhA","level":3,"time":"2024-01-19T22:48:42+00:00","remoteAddr":"84.151.165.146","user":"--","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/PC-Zentrale-1/","message":"Error: Class \"OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin\" not found at /usr/local/www/nextcloud/remote.php#62","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"DgBbumHJuYqvjk88M5Kd","level":3,"time":"2024-01-19T22:50:12+00:00","remoteAddr":"84.151.165.146","user":"--","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/user_status/api/v1/user_status?format=json","message":"Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory at /usr/local/www/nextcloud/lib/private/DB/Connection.php#139","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"X5iNdb67FdbOIROirml0","level":3,"time":"2024-01-19T22:50:12+00:00","remoteAddr":"84.151.165.146","user":"--","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/PC-Zentrale-1/","message":"Error: Class \"OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin\" not found at /usr/local/www/nextcloud/remote.php#62","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"YxjdivD7hh44OYKoZh1c","level":3,"time":"2024-01-19T22:50:12+00:00","remoteAddr":"84.151.165.146","user":"--","app":"PHP","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications?format=json","message":"Doctrine\\DBAL\\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] No such file or directory at /usr/local/www/nextcloud/lib/private/DB/Connection.php#139","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"FO8I8LwhaV8rR3eed3lP","level":3,"time":"2024-01-19T22:50:13+00:00","remoteAddr":"84.151.165.146","user":"--","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/PC-Zentrale-1/","message":"Error: Class \"OCA\\DAV\\Connector\\Sabre\\ExceptionLoggerPlugin\" not found at /usr/local/www/nextcloud/remote.php#62","userAgent":"Mozilla/5.0 (Windows) mirall/3.11.0stable-Win64 (build 20231211) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"28.0.1.1","data":{"app":"PHP"}}
"apps_paths": [
"path": "\/usr\/local\/www\/nextcloud\/apps",
"url": "\/apps",
"writable": true
"path": "\/usr\/local\/www\/nextcloud\/apps-pkg",
"url": "\/apps-pkg",
"writable": false
"logfile": "\/var\/log\/nextcloud\/nextcloud.log",
"one-click-instance": true,
"redis": {
"host": "***REMOVED SENSITIVE VALUE***"
"dbtype": "mysql",
"version": "28.0.1.1",
"overwrite.cli.url": "http:\/\/localhost",
"dbport": "",
"mysql.utf8mb4": true,
"theme": "",
"loglevel": 2,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"default_phone_region": "DE",
"mail_smtpsecure": "ssl",
"mail_smtpport": "465",
"mail_smtpauth": 1,
"opcache.interned_strings_buffer": 16,
"updater.secret": "***REMOVED SENSITIVE VALUE***"
Checked nginx and mysql log, both don’t show any obvious error
Filtering not available but pasted the nextcloud.log on the top.
If there is something else I can provide, please let me know.
