@didi44
I have cleared the log and tried to upload 2 files. One wich had around 16 Mbyte and another one with 90 Mbyte. They are now both in my cloud but it took ages and the Pi crashed after the first file.
Log:
user":"–",“app”:“PHP”,“method”:“GET”,“url”:"/cron.php",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xx Safari/537.36”,“version”:“22.1.1.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#98”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:98,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",98]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:149,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
user":"–",“app”:“PHP”,“method”:“GET”,“url”:"/cron.php",“message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/xx.x.xxxx.xx Safari/537.36”,“version”:“22.1.1.2”,“exception”:{“Exception”:“Error”,“Message”:“Function libxml_disable_entity_loader() is deprecated at /var/www/html/lib/private/Updater/VersionCheck.php#100”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/private/Updater/VersionCheck.php",“line”:100,“function”:“onError”,“class”:“OC\Log\ErrorHandler”,“type”:"::",“args”:[8192,“Function libxml_disable_entity_loader() is deprecated”,"/var/www/html/lib/private/Updater/VersionCheck.php",100]},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:101,“function”:“check”,“class”:“OC\Updater\VersionCheck”,“type”:"->",“args”:},{“file”:"/var/www/html/apps/updatenotification/lib/Notification/BackgroundJob.php",“line”:86,“function”:“checkCoreUpdate”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:},{“file”:"/var/www/html/lib/private/BackgroundJob/Job.php",“line”:51,“function”:“run”,“class”:“OCA\UpdateNotification\Notification\BackgroundJob”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/lib/private/BackgroundJob/TimedJob.php",“line”:58,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]},{“file”:"/var/www/html/cron.php",“line”:149,“function”:“execute”,“class”:“OC\BackgroundJob\TimedJob”,“type”:"->",“args”:[{“class”:“OC\BackgroundJob\JobList”},{“class”:“OC\Log”}]}],“File”:"/var/www/html/lib/private/Log/ErrorHandler.php",“Line”:92,“CustomMessage”:"–"}}
Downloads are quite fast and the WebPage in the browser is also very fast and responsive.
