Nextcloud version (eg, 20.0.5): 27.1.4
Operating system and version (eg, Ubuntu 20.04): Synology DSM 7.2 U3
docker-compose.yml:
version: '2'
volumes:
# nextcloud:
db:
services:
db:
image: mariadb:lts
restart: always
command: --transaction-isolation=READ-COMMITTED --log-bin=binlog --binlog-format=ROW
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=****
- MYSQL_PASSWORD=****
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud
restart: always
ports:
- 8082:80
links:
- db
volumes:
- /volume1/docker/nextcloud/data:/var/www/html/data
- /volume1/docker/nextcloud/config:/var/www/html/config
- /volume1/docker/nextcloud/custom_apps:/var/www/html/custom_apps
environment:
- MYSQL_HOST=db
[internet_connection_check] Fehler: GuzzleHttp\Exception\ConnectException: cURL error 7: Failed to connect to www.edri.org port 80 after 0 ms: Couldn't connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for http://www.edri.org/ at <<closure>>
[internet_connection_check] Fehler: GuzzleHttp\Exception\ConnectException: cURL error 7: Failed to connect to www.eff.org port 80 after 5209 ms: Couldn't connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for http://www.eff.org/ at <<closure>>
[internet_connection_check] Fehler: GuzzleHttp\Exception\ConnectException: cURL error 7: Failed to connect to www.startpage.com port 80 after 200 ms: Couldn't connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for http://www.startpage.com/ at <<closure>>
- Install Nextcloud
- Remove lock internet connection
- Check Log
The detailed logs do not show an addon that seems the cause.
