Dark mode by default
How do I make the dark mode default and make it so the user has to enable light mode?
I would try to change the default theme by setting the theme parameter in the configuration file.
What would I change?
https://docs.nextcloud.com/server/19/admin_manual/configuration_server/config_sample_php_parameters.html?highlight=theme
OK, I will look in to it now, and I also have a quick question
what dose this mean?
What do I need to do?
I use apache2
The messages are clear and giving detailed information what to do. Additionally I recommend to read the Nextcloud troubleshooting notes which you will find in the documentation and/or use the search function of this forum to find a matching answer. This kind of question is being asked and answered on a regular base.
Ok thank you!
were you able to give a walk through?
cheers!
was this answered in detail?
tyia
