Elpoka
March 19, 2020, 6:02pm
1
I’ve version 18.02. I use public links for sharing files and folders quite often. Sometimes it would be nice to customize the public link. Is this somehow possible?
Yes, and this has been answered before. You can use the Nextcloud link shortener from the app store:
https://apps.nextcloud.com/apps/sharerenamer
Hmm, anyone tried running it on version 18 yet? You could also run a 3rd party service such as YOURLS on your server. It is great! https://yourls.org/
Elpoka
March 19, 2020, 6:11pm
3
Thanks for your info.
I beg you a pardon, I forgot to write that I tried sharerenamer but it seems that it does not work on version 18.
Gotcha, here is the Github issue.
opened 12:12PM - 13 Dec 19 UTC
The app needs to be changed due to changes in NC 18 (share API), see https://git… hub.com/nextcloud/server/pull/15719 and https://github.com/nextcloud/socialsharing/pull/37/commits/931efc9b934ed31e80acd4437f0f253f7e7b1be7.
A new maintainer is re-writing for vue!
JonathanTreffler:master ← JonathanTreffler:v3
opened 02:58PM - 27 Oct 20 UTC
implements #21
## Todo
- [x] Implement boilerplate code for sidebar
- … [x] implement sidebar loader
- [x] call Sidebar loader
- [x] install necessary dependencies (vuejs, webpack)
- [x] add webpack configuration
- [x] add build scripts
- [x] Add functionality to sidebar
- [x] Styling
- [ ] Final Testing
<a href="https://gitpod.io/#https://github.com/JonathanTreffler/sharerenamer/pull/31"><img src="https://gitpod.io/button/open-in-gitpod.svg"/></a>
