Nextcloud version (eg, 20.0.5): 21.0.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.18.0
PHP version (eg, 7.4): 7.4
I wanted to customize Nextcloud using the Theming app so I uploaded SVG Logos, but these SVGs are not visible. When I download and open them using the same request as shown in the Networking Dev Tools I can see that there is nothing wrong with the file. It is uploaded correctly and the file is not corrupted
- Download and Setup Nextcloud 21.0.2
- Install php7.4-imagick
- Install libmagickcore-6.q16-3-extra
see https://hastebin.com/sacubaceri.json
"www.schmazda.xyz",
"schmazda.xyz"
"dbtype": "mysql",
"version": "21.0.2.1",
"overwrite.cli.url": "https:\/\/www.schmazda.xyz\/cloud",
"dbport": "",
"mysql.utf8mb4": true,
"mail_smtpmode": "smtp",
"mail_smtpsecure": "tls",
"mail_sendmailmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"redis": {
"port": 6379
"default_phone_region": "DE",
"mail_smtpport": "587",
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***"
2021/06/25 00:36:55 [error] 427#427: *1066 open() "/var/www/html/schmazda.xyz/ecp/Current/exporttool/microsoft.exchange.ediscovery.exporttool.application" failed (2: No such file or directory), client: 192.241.204.115, server: schmazda.xyz, request: "GET /ecp/Current/exporttool/microsoft.exchange.ediscovery.exporttool.application HTTP/1.1", host: "161.97.66.29"
2021/06/25 02:52:23 [error] 427#427: *1072 "/var/www/html/schmazda.xyz/owa/index.html" is not found (2: No such file or directory), client: 172.105.172.151, server: schmazda.xyz, request: "GET /owa/ HTTP/1.1", host: "161.97.66.29"
2021/06/25 03:57:32 [error] 427#427: *1082 open() "/var/www/html/schmazda.xyz/system_api.php" failed (2: No such file or directory), client: 157.230.16.235, server: schmazda.xyz, request: "GET /system_api.php HTTP/1.1", host: "161.97.66.29"
2021/06/25 03:57:32 [error] 427#427: *1086 open() "/var/www/html/schmazda.xyz/c/version.js" failed (2: No such file or directory), client: 157.230.16.235, server: schmazda.xyz, request: "GET /c/version.js HTTP/1.1", host: "161.97.66.29"
2021/06/25 03:57:32 [error] 427#427: *1090 open() "/var/www/html/schmazda.xyz/streaming/clients_live.php" failed (2: No such file or directory), client: 157.230.16.235, server: schmazda.xyz, request: "GET /streaming/clients_live.php HTTP/1.1", host: "161.97.66.29"
2021/06/25 03:57:32 [error] 427#427: *1094 open() "/var/www/html/schmazda.xyz/stalker_portal/c/version.js" failed (2: No such file or directory), client: 157.230.16.235, server: schmazda.xyz, request: "GET /stalker_portal/c/version.js HTTP/1.1", host: "161.97.66.29"
2021/06/25 03:57:32 [error] 427#427: *1098 open() "/var/www/html/schmazda.xyz/stream/live.php" failed (2: No such file or directory), client: 157.230.16.235, server: schmazda.xyz, request: "GET /stream/live.php HTTP/1.1", host: "161.97.66.29"
2021/06/25 04:29:27 [error] 427#427: *1104 open() "/var/www/html/schmazda.xyz/.env" failed (2: No such file or directory), client: 40.113.20.14, server: schmazda.xyz, request: "GET /.env HTTP/1.1", host: "161.97.66.29"
2021/06/25 07:50:46 [error] 427#427: *1123 open() "/var/www/html/schmazda.xyz/.env" failed (2: No such file or directory), client: 139.99.122.199, server: schmazda.xyz, request: "GET /.env HTTP/1.1", host: "161.97.66.29"
2021/06/25 08:22:44 [error] 427#427: *1132 open() "/var/www/html/schmazda.xyz/favicon.png" failed (2: No such file or directory), client: 162.62.123.46, server: schmazda.xyz, request: "GET //favicon.png HTTP/1.1", host: "161.97.66.29"
2021/06/25 08:36:26 [error] 427#427: *1133 open() "/var/www/html/schmazda.xyz/admin/config.php" failed (2: No such file or directory), client: 77.247.108.77, server: schmazda.xyz, request: "GET /admin/config.php HTTP/1.1", host: "161.97.66.29"
2021/06/25 09:43:18 [crit] 427#427: *1156 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 192.241.218.90, server: 0.0.0.0:443
2021/06/25 09:58:13 [error] 427#427: *1158 open() "/var/www/html/schmazda.xyz/apple-touch-icon.png" failed (2: No such file or directory), client: 82.145.215.206, server: schmazda.xyz, request: "GET /apple-touch-icon.png HTTP/1.1", host: "schmazda.xyz"
2021/06/25 11:10:12 [error] 427#427: *1190 open() "/var/www/html/schmazda.xyz/.env" failed (2: No such file or directory), client: 103.209.252.42, server: schmazda.xyz, request: "GET /.env HTTP/1.1", host: "161.97.66.29"
2021/06/25 11:16:56 [error] 427#427: *1192 open() "/var/www/html/schmazda.xyz/owa/auth/logon.aspx" failed (2: No such file or directory), client: 192.241.213.99, server: schmazda.xyz, request: "GET /owa/auth/logon.aspx?url=https%3a%2f%2f1%2fecp%2f HTTP/1.1", host: "161.97.66.29"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/cloud//groups HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/avatar/mathias/32?v=2 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/search/providers?from=%2Fcloud%2Fsettings%2Fadmin%2Foverview HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocm-provider/ HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/settings/ajax/checksetup HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/index.php/.well-known/webfinger HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PROPFIND /cloud/remote.php/dav/ HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:57 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:49:59 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/index.php/settings/integrity/failed HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:50:01 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//diskdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:50:01 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:50:02 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:50:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:50:21 [error] 427#427: *1237 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/theming/manifest?v=72 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:51:16 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:51:24 [error] 427#427: *1202 open() "/var/www/html/schmazda.xyz/favicon.ico" failed (2: No such file or directory), client: 77.190.133.234, server: schmazda.xyz, request: "GET /favicon.ico HTTP/2.0", host: "schmazda.xyz", referrer: "https://schmazda.xyz/"
2021/06/25 12:51:28 [error] 427#427: *1202 open() "/var/www/html/schmazda.xyz/hello" failed (2: No such file or directory), client: 77.190.133.234, server: schmazda.xyz, request: "GET /hello HTTP/2.0", host: "schmazda.xyz"
2021/06/25 12:51:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:52:30 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:52:47 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:53:01 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:53:46 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:54:00 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:54:58 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:55:13 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:56:12 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:56:26 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:57:23 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/settings/apps/list HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:57:38 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/serverinfo/update HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:57:52 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/serverinfo/api/v1//basicdata?format=json HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:59:26 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:59:33 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 12:59:33 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/settings HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:01:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:01:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:02:23 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:03:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:03:35 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:04:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:05:48 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:06:35 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:07:23 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:07:56 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:09:23 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:09:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:09:48 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:10:48 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:11:37 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:12:48 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:13:37 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:14:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:14:57 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:16:37 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:16:48 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:17:14 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:17:31 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:18:01 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/get?offset=325&count=25&levels=11111 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:19:01 [error] 427#427: *1625 open() "/var/www/html/schmazda.xyz/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "POST /vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:01 [error] 427#427: *1624 open() "/var/www/html/schmazda.xyz/api/jsonws/invoke" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "POST /api/jsonws/invoke HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:01 [error] 427#427: *1626 open() "/var/www/html/schmazda.xyz/vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "GET /vendor/phpunit/phpunit/src/Util/PHP/eval-stdin.php HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:03 [error] 427#427: *1627 open() "/var/www/html/schmazda.xyz/index.php" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "GET /index.php?s=/Index/\think\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP21 HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:04 [error] 427#427: *1629 open() "/var/www/html/schmazda.xyz/mifs/.;/services/LogService" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "POST /mifs/.;/services/LogService HTTP/1.1", host: "161.97.66.29:443", referrer: "https://161.97.66.29:443"
2021/06/25 13:19:05 [error] 427#427: *1632 "/var/www/html/schmazda.xyz/console/index.html" is not found (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "GET /console/ HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:07 [error] 427#427: *1631 open() "/var/www/html/schmazda.xyz/wp-content/plugins/wp-file-manager/readme.txt" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "GET /wp-content/plugins/wp-file-manager/readme.txt HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:07 [error] 427#427: *1633 open() "/var/www/html/schmazda.xyz/Autodiscover/Autodiscover.xml" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "POST /Autodiscover/Autodiscover.xml HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:09 [error] 427#427: *1634 open() "/var/www/html/schmazda.xyz/_ignition/execute-solution" failed (2: No such file or directory), client: 45.146.165.123, server: schmazda.xyz, request: "GET /_ignition/execute-solution HTTP/1.1", host: "161.97.66.29:443"
2021/06/25 13:19:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:20:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:20:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:21:21 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/settings/admin/log/download HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:22:03 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:22:40 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/poll?lastReqId=mfwM1E2PhDn5V1smdSgh HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:23:14 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/apps/logreader/get?offset=750&count=25&levels=11111 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:23:33 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:24:03 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/logreader/levels HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:24:28 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/logreader/levels HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:26:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:26:34 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:27:23 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "PUT /cloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
2021/06/25 13:28:04 [error] 427#427: *1202 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 77.190.133.234, server: schmazda.xyz, request: "GET /cloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "www.schmazda.xyz"
