I’m currently developing a custom Nextcloud app, and I’m trying to add a custom action to the standard ‘Files’ app for PDF documents in the ‘All files’ list.
The first goal is to add a ‘Direct sign’ action that will send the selected PDF to an external signing service via REST and open the viewer in a new tab so that it can be signed.
I created the app here and set up the dev environment with Docker; it’s version 34.
My script is loaded, but I think I’ve done it the wrong way because I can’t see any custom actions in the Files UI.
This is my Application.php file, which loads the JavaScript file.
class Application extends App implements IBootstrap {
public const APP_ID = 'signapp';
/** @psalm-suppress PossiblyUnusedMethod */
public function __construct() {
parent::__construct(self::APP_ID);
public function register(IRegistrationContext $context): void {
Util::addScript(self::APP_ID, self::APP_ID. '-pdfContextMenu', 'files');
public function boot(IBootContext $context): void {
Here is my JavaScript code. In the console, I can see ‘load pdfContextMenu.js’ so loading should not be the problem. However, the enabled function is neither entered nor executed.
import {
FileAction,
registerFileAction,
FileListAction,
registerFileListAction,
} from "@nextcloud/files";
import { t } from "@nextcloud/l10n";
import SvgIcon from "../img/file-sign.svg";
console.log("load pdfContextMenu.js");
registerFileAction(
new FileAction({
displayName: () => t("sign_file", "sign file"),
mime: "application/pdf",
enabled: (nodes) => {
console.log("Test enabled for nodes", nodes);
return nodes.every((node) => node.mime === "application/pdf");
iconSvgInline: () => SvgIcon,
async exec(file, view, dir) {
console.log("Demo");
return true;
registerFileListAction(
new FileListAction({
displayName: () => t("sign_file_list", "sign file (list)"),
console.log("Test list enabled for nodes", nodes);
exec: (files) => {
console.log("Demo list");
Is it possible to add one or more custom actions like this, and if so, what is required?
Once the first goal has been achieved, I would like to add an action that opens a modal. Inside the modal, the user has to enter an email address and send the document there for remote signing.
Thank you in advance, and kind regards.
Jan
