Curl Installation Script for Raspberry Pi Trixie
    • Not installed yet
    • Raspberry Pi Trixie
    • Do I have to install prior to running curl command?
    • Yes for this hardware and software pair
    • Right away at first attempt to install
    • curl installation script
Unable to use curl installation command on Raspberry Pi 4 Trixie:
curl -sSL https://raw.githubusercontent.com/nextcloud/nextcloudpi/master/install.sh | bash
  1. Fresh installation of Trixie on Raspberry Pi 4
  2. Run curl installation command
  3. Error message: “unsupported distro
PASTE HERE
PASTE
PASTE HERE
NextcloudPi not installed, as yet.
You have to take “bookworm” as ncp still doesn’t support “trixie”.
btw it is one of the best error messages one can get :grinning_face:
https://github.com/nextcloud/nextcloudpi/releases
Thanks! Self-inflicted issue closed.
Regards.
