I have renewed the letsencrypt certificate without result. The install was shortly moved from another server.
I can login and use it normally with https, the browser shows the right certificate.
Am I overseeing something?
example
longer
example
here
Nextcloud version 12.0.3
Operating system and version - Ubuntu 16.04
Apache or nginx version Apache 2.4.18
PHP version 5.6
Is this the first time you’ve seen this error? Y
- start the update to 13.04
|Error|PHP|Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. at Unknown#0|2018-04-24T23:39:18+0200|
|Error|index|InvalidArgumentException: Unable to parse malformed url: http://|2018-04-24T23:31:02+0200|
|Error|index|InvalidArgumentException: Unable to parse malformed url: https://|2018-04-24T23:31:01+0200|
|Error|PHP|Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. at Unknown#0|2018-04-24T23:30:33+0200|
