cURL error 60: SSL certificate problem: certificate has expired
    • 32.0.5
    • Debian 13
    • Nginx 1.26.3
    • 8.4 ( was 8.3 before )
    • yes
    • today after updating nextcloud
    • manual archive
    • no
Hello, after updating my nextcloud to version 32.0.5, I am suddenly unable to update any app or do any task connecting to outside sources at all. I continously get the curl error 60 with description “certificate has expired”. The thing is, the destination certificate has most certainly not expired ( github.com ). When I try running curl directly on the destination url ( https://github.com/nextcloud-releases/calendar/releases/download/v6.2.0/calendar-v6.2.0.tar.gz ) I get no error at all. When I tried to reproduce the error using a small php script ( see below ) it also finished without any problem. When trying to add debug output to nextcloud/guzzlehttp, I also was unable to get any informative output. I tried disabling the firewall, forcing curl to IPv4 ( as suggested by a similar issue #240104 ) updating the ca bundle in ressources/config/ca-bundle.crt, updating the system ca bundle, re-installing nextcloud etc etc etc. Nothing I tried worked.
$ch = curl_init("https://github.com/ONLYOFFICE/onlyoffice-nextcloud/releases/download/v9.12.0/onlyoffice.tar.gz");
//curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, true);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 2);
curl_setopt($ch, CURLOPT_CAINFO, "resources/config/ca-bundle.crt");
// resources/config/ca-bundle.crt
if(curl_exec($ch) === false) {
        var_dump(curl_error($ch));
} else {
//      var_dump(curl_getinfo($ch));
        echo "<pre>" . print_r(curl_version(), true) . "</pre>";
  1. Update to latest nextcloud
  2. Try installing any app
  3. Profit
( honestly I cannot tell you why this is happening. Only nextcloud seems to be affected by this, other web applications do not seem to face this issue, and I cannot reproduce it outside of nextcloud )
 {"reqId":"YjnJbLzU6hgAFZZXaN2b","level":3,"time":"2026-02-11T17:15:35+00:00","remoteAddr":"2a02:8071:5be0:ba10:1031:941b:5f37:4c7e","user":"#REMOVED FOR PRIVACY#","app":"settings","method":"POST","url":"/settings/apps/enable","scriptName":"/index.php","message":"could not enable apps","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:147.0) Gecko/20100101 Firefox/147.0","version":"32.0.5.0","exception":{"Exception":"GuzzleHttp\\Exception\\RequestException","Message":"cURL error 60: SSL certificate problem: certificate has expired (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://github.com/nextcloud-releases/calendar/releases/download/v6.2.0/calendar-v6.2.0.tar.gz","Code":0,"Trace":[{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":205,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":157,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/Http/Client/DnsPinMiddleware.php","line":150,"function":"{closure:{closure:GuzzleHttp\\Middleware::tap():137}:138}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"{closure:{closure:OC\\Http\\Client\\DnsPinMiddleware::addDnsPinning():104}:105}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"{closure:{closure:GuzzleHttp\\Middleware::cookies():28}:29}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"{closure:{closure:GuzzleHttp\\Middleware::httpErrors():60}:61}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/lib/private/Http/Client/Client.php","line":206,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/Installer.php","line":238,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/clients/client1/web98/web/apps/settings/lib/Controller/AppSettingsController.php","line":571,"function":"downloadApp","class":"OC\\Installer","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/AppFramework/Http/Dispatcher.php","line":204,"function":"enableApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/clients/client1/web98/web/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/clients/client1/web98/web/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/clients/client1/web98/web/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/clients/client1/web98/web/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":276,"message":"could not enable apps","exception":[],"CustomMessage":"could not enable apps"},"id":"698cbcbd0df9c"}
            "127.0.0.1",
        "dbtype": "mysql",
        "version": "32.0.5.0",
        "overwrite.cli.url": "#REMOVED FOR PRIVACY#",
        "dbport": "",
        "redis": {
            "port": 6379,
            "dbindex": 5
        "mail_smtpmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "theme": "",
        "loglevel": 0,
        "csrf.optout": [
            "\/^WebDAVFS\/",
            "\/^Microsoft-WebDAV-MiniRedir\/",
            "\/KeeWeb\\\/\\d[.]\\d[.]\\d\/",
            "\/KeeWeb\\\/\\d+\\.\\d+\\.\\d+\/"
        "app_install_overwrite": [
            "keeweb",
            "twofactor_gateway"
        "default_phone_region": "DE",
        "mysql.utf8mb4": true,
        "ncd_admin_settings": {
            "disallow_aria2_settings": "1"
        "mail_smtpsecure": "ssl",
        "mail_smtpport": "465",
        "enable_previews": true,
        "preview_concurrency_new": 8,
        "enabledPreviewProviders": [
            "OC\\Preview\\Movie",
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\MP4",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\PDF",
            "OC\\Preview\\MOV"
        "apps_paths": [
                "path": "\/var\/www\/clients\/client1\/web98\/web\/apps\/",
                "url": "\/apps",
                "writable": true
        "updater.secret": "***REMOVED SENSITIVE VALUE***"
  - activity: 5.0.0-dev.0
  - circles: 32.0.0
  - comments: 1.22.0
  - contactsinteraction: 1.13.1
  - dav: 1.34.2
  - federation: 1.22.0
  - files: 2.4.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - logreader: 5.0.0-dev.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - systemtags: 1.22.0
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - viewer: 5.0.0-dev.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0 (installed 32.0.0)
  - dashboard: 7.12.0 (installed 7.7.0)
  - encryption: 2.20.0
  - files_external: 1.24.1
  - firstrunwizard: 5.0.0-dev.0 (installed 2.17.0)
  - sharebymail: 1.22.0 (installed 1.18.0)
  - support: 4.0.0-dev.0 (installed 1.11.1)
  - survey_client: 4.0.0-dev.0 (installed 1.14.0)
  - user_ldap: 1.23.0
  - user_status: 1.12.0 (installed 1.8.1)
  - weather_status: 1.12.0 (installed 1.8.0)
I did in fact disable IP6 from my server completely and then my downloads worked. My provider is OVH - maybe yours is the same. The orders below allowed me to determine the expired certificate:
HOST=release-assets.githubusercontent.com # replace with the one you see
openssl s_client -connect $HOST:443 -servername $HOST </dev/null 2>/dev/null
| openssl x509 -noout -subject -issuer -dates
Hope this helps
Thank you very much for your reply. I actually did try that, and it still worked without issue. I was losing my mind over this, but you pointed me in the right direction because I found it.
  1. release-assets.githubusercontent.com does not have an AAAA record. It only has an A record.
  2. My server is part of a domain, so a search domain is setup in the system’s resolv.conf.
Now the funny bit: apparently the search domain setting was causing all domains to resolve back against my own server because of a wildcard entry. So instead of looking up release-assets.githubusercontent.com and failing because there is no AAAA record, it would append this domain to my own (e.g., release-assets.githubusercontent.com.example.com), and the wildcard record would be returned and cause curl to actually connect to my own server. And because my server’s SSL cert is not valid for release-assets.githubusercontent.com, I would get an expired certificate error.
So the only fix I had to apply was removing this line from my resolv.conf file:
search example.com
