I have running Nextcloud instance, everything seems to work fine but when I want to add APP from GITHUB - for example Contacts app, I get the following error:
cURL error 35: OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.com:443
Here are more details about setup/system/environment:
I was told by out ‘network team’ that access to github.com:443 is set to allow so its probably server issue or curl issue … but of course they lied and now as they REALLY allowed access to github.com:443 everything works properly.
Thanks You for suggestions and sorry for wasting your time.
