Nextcloud version (eg, 20.0.5): 28.0.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): nginx
PHP version (eg, 7.4): 8.1
Hello since I updated my nextcloud from 28.0.2 to 28.0.3, my browser keeps telling me that It can’t apply the style.
error log:
overview:1 Refused to apply style from 'https://cloud.domain.com/apps/user_status/css/user-status-menu.css?v=5dbcc382-9' because its MIME type ('application/octet-stream') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
Hello, logoderking
Would you please share your solution? I am facing similar situation after a new installation - looking like rewrite problem.
2024/04/13 20:46:47 [error] 51996#51996: *430 openat() "/home/admin/web/cloud.example.com/public_html/index.php/apps/theming/theme/default.css" failed (20: Not a directory), client: 123.123.123.123, server: cloud.example.com, request: "GET /index.php/apps/theming/theme/default.css?plain=1&v=6e3f3bf0 HTTP/2.0", host: "cloud.example.com"
2024/04/13 20:46:47 [error] 51996#51996: *430 openat() "/home/admin/web/cloud.example.com/public_html/index.php/apps/theming/theme/light.css" failed (20: Not a directory), client: 123.123.123.123, server: cloud.example.com, request: "GET /index.php/apps/theming/theme/light.css?plain=1&v=6e3f3bf0 HTTP/2.0", host: "cloud.example.com"
2024/04/13 20:46:47 [error] 51996#51996: *430 openat() "/home/admin/web/cloud.example.com/public_html/index.php/apps/theming/theme/light.css" failed (20: Not a directory), client: 123.123.123.123, server: cloud.example.com, request: "GET /index.php/apps/theming/theme/light.css?plain=0&v=6e3f3bf0 HTTP/2.0", host: "cloud.example.com"
Thanks in advance.
Regards,
Willie S.
Hey my problem was that somehow my nginx configuration didn’t support the MIME format. I changed the config and it worked. Your error says that there is no directory. Check which one is missing and try to reinstall it
Same issue here. Missing directory is not part of the installation package. I also assume an issue with the nginx config, but I’m not really good at that. How to check on the meme config problem?
