Nextcloud version: 12.0.3
Operating system and version: Arch Linux
Apache or nginx version: nginx 1.12.1
PHP version: php-fpm 7.1.8
Is this the first time you’ve seen this error?: Yes
Can you reliably replicate it? (If so, please outline steps):
Just a fresh install of Nextcloud 12.0.3 does this (with having my data files copied)
When accessing Nextcloud through the web (or through the mobile application on Android) the whole interface is scrambled as no CSS nor JS gets loaded. In my Firefox console log I get quite som errors regarding Content Security Policy, but main issue is that CSS and JS seem to be loaded improperly due to being redirected by the NGINX server to /apps/files/ instead of the actual file.
Can’t go there.
?php
'instanceid' => '....',
'passwordsalt' => '.......',
'secret' => '.....',
0 => '...',
'datadirectory' => '....',
'overwrite.cli.url' => '.......',
'trusted_proxies' => ['...'],
'overwritewebroot' => '/',
"overwritecondaddr" => "^....$",
'version' => '12.0.3.3',
'dbname' => '.....',
'dbhost' => 'localhost',
'dbuser' => '.........',
'dbpassword' => '.....',
'log_type' => 'file',
'logfile' => '/var/log/nextcloud.log',
'loglevel' => 2,
'syslog_tag' => 'Nextcloud',
'log.condition' =>
'shared_secret' => '......',
'users' =>
0 => 'sample-user',
'apps' =>
0 => 'files',
'logdateformat' => 'F d, Y H:i:s',
'logtimezone' => '....',
'log_query' => false,
'cron_log' => true,
'log_rotate_size' => 20971520,
'auth.bruteforce.protection.enabled' => true,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'updater.secret' => '...........',
'theme' => '',
[my-ip] - - [16/Nov/2017:09:29:35 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:37 ] "GET /core/css/jquery-ui-fixes.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:37 ] "GET /core/vendor/select2/select2.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:38 ] "GET /core/vendor/jquery-ui/themes/base/jquery-ui.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:38 ] "GET /apps/files_versions/css/versions.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:38 ] "GET /apps/ojsxc/css/jsxc.oc.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:38 ] "GET /apps/files_pdfviewer/css/style.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:38 ] "GET /apps/files_videoplayer/css/style.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /apps/notifications/css/styles.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /apps/activity/css/style.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /core/css/jquery.ocdialog.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /apps/files_trashbin/css/trash.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /apps/comments/css/comments.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:39 ] "GET /apps/gallery/css/gallerybutton.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:40 ] "GET /apps/gallery/css/slideshow.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:40 ] "GET /core/vendor/core.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:40 ] "GET /apps/systemtags/css/systemtagsfilelist.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:40 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:41 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:41 ] "GET /apps/gallery/css/share.css?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:41 ] "GET /apps/files/ HTTP/1.0" 200 38667 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:41 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:42 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:42 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:42 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:42 ] "GET /apps/files/ HTTP/1.0" 200 38671 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:43 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:43 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:43 ] "GET /apps/files/ HTTP/1.0" 200 38667 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:43 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /settings/img/help.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /core/img/actions/logout.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /apps/files/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /settings/img/users.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /core/img/actions/delete.svg HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:44 ] "GET /apps/activity/img/activity.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /apps/notes/img/notes.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /apps/gallery/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /apps/tasks/img/tasks.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /apps/weather/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /core/search/js/search.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:45 ] "GET /settings/img/admin.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:46 ] "GET /settings/img/apps.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:46 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:46 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:46 ] "GET /settings/img/personal.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:47 ] "GET /apps/ojsxc/js/jsxc/lib/jquery.slimscroll.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:47 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:47 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:48 ] "GET /apps/files/ HTTP/1.0" 200 38661 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:48 ] "GET /apps/ojsxc/js/jsxc/lib/jquery.fullscreen.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:48 ] "GET /apps/files/ HTTP/1.0" 200 38667 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:48 ] "GET /apps/files/ HTTP/1.0" 200 38665 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:48 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:49 ] "GET /apps/ojsxc/js/jsxc/lib/jsxc.dep.min.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:49 ] "GET /apps/files/ HTTP/1.0" 200 38663 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:49 ] "GET /apps/ojsxc/js/jsxc/jsxc.min.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:49 ] "GET /apps/ojsxc/js/ojsxc.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:49 ] "GET /apps/files_pdfviewer/js/previewplugin.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:51 ] "GET /apps/files_videoplayer/js/viewer.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:51 ] "GET /core/js/jquery-ui-fixes.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:51 ] "GET /core/js/files/fileinfo.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:51 ] "GET /core/js/files/client.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:52 ] "GET /core/js/contactsmenu.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:52 ] "GET /apps/files_sharing/js/app.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:52 ] "GET /apps/files_sharing/js/sharedfilelist.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:53 ] "GET /apps/files_trashbin/js/app.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:53 ] "GET /apps/files_trashbin/js/filelist.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:53 ] "GET /core/js/oc-backbone-webdav.js?v=f75508bec9e0ec6e027f374af5d89059-3 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:54 ] "GET /apps/notes/img/notes.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /apps/files/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /apps/activity/img/activity.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /apps/gallery/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /apps/tasks/img/tasks.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /settings/img/personal.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:55 ] "GET /settings/img/admin.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:56 ] "GET /apps/weather/img/app.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
[my-ip] - - [16/Nov/2017:09:29:56 ] "GET /settings/img/apps.svg?v=f75508bec9e0ec6e027f374af5d89059 HTTP/1.0" 302 0 "-" "[my-browser]"
I am using the NGINX configuration files which are presented at the manual. My NGINX also sits behind a proxy where my SSL certificate lives, but that was not an issue until I updated to 12.0.3 (manual update, went alright).
Please, assist! Thank you!!
