CSP CSS and Javacript block
Hi, new to NextCloud. I created an index doing simple code and created folder with my files.
link rel=“stylesheet” type=“text/css” href=“/css/datatables.css”
script type=“text/javascript” src=“/src/datatables.js”
but i am getting a error with the css that it been “Refuse to apply the style” and for the javascript i getting the (blocked:csp).
How can i unblock my css and javascript? there is a code that will bypass this problem or do i need to change file?
Are you trying to make an html page?
That is dangerous on a cloud server, so you have been warned.
But serving a directory with an index.html file and/or any other html file is possible with this tiny app.
You should know what you are doing, because you have to edit the CSP entries a bit for the needs of your usecase.
btw: The app has not been maintained for a long time and needs to be adjusted so that it does not produce errors in the log ({$var} instead of ${var}).
Here a random calculator written in javascript as an example with html and css:
Seen as normal cloud files
Seen as website
Much and good luck,
ernolf
