example
longer
example
here
Nextcloud version: 22.2.1
Operating system and version: Ubuntu 20.04
nginx version 1.21.3
PHP version: 7.4
every now and then I get the message:
Letzte Cron-Job-Ausführung: Vor X Tagen. Check the background job settings
Is this the first time you’ve seen this error? (Y/N): No
- update to 22.2.0
Keine Serverlogs Alles funktioniert gut
config.php
'instanceid' => 'X',
'passwordsalt' => 'X',
'secret' => 'X',
0 => '192.168.XXX.XX',
1 => 'cloud.xxxxxx.xx',
'datadirectory' => '/xxxx/nextcloud_data',
'version' => '22.2.0.2',
'overwrite.cli.url' => 'https://192.168.XX.XX',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud_user',
'dbpassword' => 'PWPWPWPW',
'log_type' => 'file',
'logfile' => '/var/log/nextcloud.log',
'logfilemode' => 0640,
'loglevel' => '2',
'logdateformat' => 'F d, Y H:i:s',
'redis' =>
'host' => '/run/redis/redis-server.sock',
'port' => 0,
'timeout' => 0.0,
'default_phone_region' => 'BE',
'logtimezone' => 'Europe/XXXXXXXXXXXX',
'auth.bruteforce.protection.enabled' => true,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'cloudatlas',
'mail_domain' => 'vvvvvvvvvv.vv',
'mail_smtphost' => 'vvvvvvvvvvvvvvvvvv.vvv',
'mail_smtpport' => '465',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpname' => 'XXXXXXXXXXXXXXX@iXXXXXX',
'mail_smtppassword' => 'XXXXXXXXXXXXXXXXXXXXX',
'app_install_overwrite' =>
0 => 'ocsms',
1 => 'podcast',
2 => 'whiteboard',
3 => 'forms',
4 => 'drop_account',
'theme' => '',
'skeletondirectory' => '/XXXXXXXXXX/XXXXXXXXXXXXXXXXX',
'data-fingerprint' => 'XXXXXXXXXXXXXXXXXXXXX',
'updater.secret' => '$XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.',
The output of your nginx/system log in /var/log/____:
nothing
Since the cloud is updated is happens now and then. I renewed cron.php. Everything looks fine, but it’ s not. Does anyone have any idea?
Best Joon
