Cronjob is running and lastcron is updated in DB but NC says last cron was more than a day ago
  • Nextcloud Server version (e.g., 32.0.x):
    • 32.0.6
    • Ubuntu 24.04
    • 2.4.58
    • HAProxy 2.8.16
    • 8.4
    • Yes
    • Yesterday
    • Bare Metal/LXC
    • Mod-security
Some jobs have not been executed since one day siden. Please consider increasing the execution frequency.
What I have done:
1:
delete from public.oc_appconfig
where appid = 'core'
and configkey like '%lastcron%';
DELETE 1
SELECT * from public.oc_appconfig
appid | configkey | configvalue | type | lazy
(0 rows)
As expected, I now has “Background job has not been run yet!”
2:
sudo -u www-data php -f /var/www/nextcloud/cron.php
core | lastcron | 1772446640 | 8 | 0
(1 row)
And I got:
  1. Steps are litterally explained above
{"reqId":"FhQpTDp5GgBKRX5F8xM1","level":0,"time":"2026-03-02T10:41:58+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","scriptName":"/var/www/nextcloud/cron.php","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"32.0.6.1","occ_command":["/var/www/nextcloud/cron.php"],"exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASCLIMIT 1","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":291,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":196,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":157,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/lib/private/DB/Connection.php","Line":407,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_collectives_sessions","oc_user_status"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
        "version": "32.0.6.1",
        "overwrite.cli.url": "https:\/\/mydomain.dom",
        "htaccess.RewriteBase": "\/",
        "overwriteprotocol": "https",
        "data-fingerprint": "d518a5c48eb3e1f261fdacc48e7aae9e",
        "default_phone_region": "DK",
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "twofactor_enforced_excluded_groups": [
            "admin",
            "NCNoMFA"
        "share_folder": "\/Delinger",
        "loglevel": 0,
        "app_install_overwrite": {
            "1": "cas",
            "2": "otpmanager",
            "3": "secrets",
            "4": "cfg_share_links",
            "6": "files_texteditor",
            "7": "side_menu"
        "theme": "",
        "memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "timeout": 0
        "dbtype": "pgsql",
        "dbport": "5432",
            "mydomain.dom",
            "127.0.0.1",
            "class a IP",
            "localhost",
            "myotherdomain.dom"
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "pipe",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": true,
                "verify_peer": false,
                "verify_peer_name": false
        "mail_smtpport": "1025",
        "mail_smtpauth": 1,
        "app.mail.verify-tls-peer": false,
        "defaultapp": "",
        "twofactor_enforced_excluded_groups=admin": ""
I didn’t check the db for the last Cronjob run, but I have the same problem with an almost similar setup. The Cron Job itself seems to start, it is shown when I look at it via systemctl status cron.
I just noticed taht toady after Update to 32.0.6, but the Cloud said the Job did run last two month ago. So I would be interested in some hints too.
Some more: I get an error message about missing php modules now; this happemd first after my previous post. Nevertheless I installed the missing modules, but the error message still exists. mbstring, GD, cURL were missing for PHP 8.4 (and 8.5…). So now?
I found a solution: Set the Cron job to explicitly use a PHP version that’s compatible with Nextcloud. My system updated itself to PHP 8.5 (don’t remember when…). I changed the crontab now to
* * * * * /usr/bin/php8.4 -f /path/to/your/nextcloud/cron.php
and the job started again, also delivering missing notifications. The error ist gone now, nevertheless there is still the message taht some jobs didn’t run for 3 month now. But tehre are other automated background jobs that also may have stopped cause of the wrong php version, but those jobs don’t depend on the cron settings. So I’ll wait at least until tomorrow if those message will also dissapear.
Yeah that did it. Thank you. I do not know what happened. This is the excact way my cronjob has been for ages (I actually changes it to the specific version even, when I upgrades PHP version). I tested with
root@nc:~# sudo -u www-data php -v
PHP 8.4.18 (cli) (built: Feb 13 2026 16:00:19) (NTS)
Copyright (c) The PHP Group
Built by Debian
Zend Engine v4.4.18, Copyright (c) Zend Technologies
with Zend OPcache v8.4.18, Copyright (c), by Zend Technologies
root@nc:~#
Hence the use of the php without full path, should be good enough. For some reason, then even when the above is good and well, running the following did not work:
But this one did:
sudo -u www-data /usr/bin/php8.4 -f /var/www/nextcloud/cron.php
There should not be any difference. However, thank you. It did solve my issue.
