Cron not working with PHP fatal error for DB connection
- Admin page stats that Cron hasn’t run for days.
- I check Cron on the server which is fine
- I run the Cron job and get errors on line 64 of the Connection.php.
- I searched for similar problems.
- I logged in with nextcloud credentials to the mysql server, all okay.
- Check logs.
- Stuck at what could be wrong.
Nextcloud version 15.0.6 & 15.0.7:
Operating system and version Ubuntu 16.04:
Apache2 2.4.18: I am running it through a reverse proxy which has same version.
PHP version 7.3.4):
I have been running Nextcloud for sometime, approximately since the move from owncloud occurred, and in the last few days I saw on the admin page that cron hasn’t been run for 15 days. I checked my server and nothing obvious has been changed except maybe some security updates.
I ran
php -f /var/www/nextcloud/cron.php
and got
PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: could not find driver in /var/www/nextcloud/lib/private/DB/Connection.php:64
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configura in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
Stack trace:
I can log into the mysql server from the nextcloud server using the nextcloud login and password. I did the update to 15.0.7 incase there was a bug and gave no errors which leads me to believe that nextcloud can log into the database.
Is this the first time you’ve seen this error? Yes:
- let Nextcloud use cron
or - run
The output of your Nextcloud log has nothing related to this, only the recent update and deleting images or music app related:
The output of your config.php file:
'instanceid' => 'XXXXXX',
'passwordsalt' => 'XXXXXX',
'secret' => 'XXXXXX',
0 => '192.168.1.12', #nextcloud server
1 => 'XXXXXX',
'overwrite.cli.url' => 'https://XXXXXX',
'htaccess.RewriteBase' => '/nextcloud',
'version' => '15.0.7.0',
'dbname' => 'nextcloud',
'dbhost' => '192.168.1.16:3306',
'dbuser' => 'XXXXXX',
'dbpassword' => 'XXXXXX',
'trusted_proxies' =>
0 => '192.168.1.5', #proxy server
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'XXXXXX',
'mail_smtphost' => 'XXXXXX',
'mail_smtpport' => 'XXXXXX',
'mail_smtpauth' => 1,
'mail_smtpname' => 'XXXXXX',
'mail_smtppassword' => 'XXXXXX',
'onlyoffice' =>
'verify_peer_off' => true,
'jwt_secret' => 'XXXXXX',
'jwt_header' => 'XXXXXX',
'updater.secret' => 'XXXXXX',
The output of your Apache error log in :
[Sat Apr 20 06:25:05.061637 2019] [mpm_prefork:notice] [pid 467] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Sat Apr 20 06:25:05.061714 2019] [core:notice] [pid 467] AH00094: Command line: '/usr/sbin/apache2'
[Sat Apr 20 07:01:38.399351 2019] [autoindex:error] [pid 2296] [client 192.168.1.5:48992] AH01276: Cannot serve directory /var/www/nextcloud/: No matching DirectoryIndex (none) found, and server-generated directory index forbidden by Options directive
[Sat Apr 20 07:02:19.254706 2019] [authz_core:error] [pid 2294] [client 192.168.1.5:49206] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 07:02:47.976034 2019] [authz_core:error] [pid 2595] [client 192.168.1.5:49252] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:26:10.428502 2019] [mpm_prefork:notice] [pid 467] AH00169: caught SIGTERM, shutting down
[Sat Apr 20 12:26:32.636931 2019] [mpm_prefork:notice] [pid 476] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Sat Apr 20 12:26:32.637119 2019] [core:notice] [pid 476] AH00094: Command line: '/usr/sbin/apache2'
[Sat Apr 20 12:34:10.737823 2019] [php7:error] [pid 482] [client 192.168.1.5:51166] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Connection refused in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doc in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
[Sat Apr 20 12:34:10.739029 2019] [php7:error] [pid 482] [client 192.168.1.5:51166] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Connection refused in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doc in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
[Sat Apr 20 12:47:03.935854 2019] [authz_core:error] [pid 942] [client 192.168.1.5:51490] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:47:13.744760 2019] [authz_core:error] [pid 513] [client 192.168.1.5:51536] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:53:42.156522 2019] [authz_core:error] [pid 1030] [client 192.168.1.5:51960] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:53:48.482358 2019] [authz_core:error] [pid 945] [client 192.168.1.5:51986] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:54:12.642622 2019] [authz_core:error] [pid 1039] [client 192.168.1.5:52070] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Sat Apr 20 12:54:31.279909 2019] [authz_core:error] [pid 1031] [client 192.168.1.5:52096] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
Looking at the above I don’t know what would be calling for the database through 192.168.1.5 ( which is the reverse proxy server) as it is already configured to be 192.168.1.16 (the database).
If you can point me in the right direction on how to resolve this I would be most grateful.
Thanks
