Cron Job is not running
Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
[/details]
Nextcloud version (eg, 20.0.5): 24.0.7
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04.1
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 7.4): 8.1.2
The issue you are facing: My Cron Job is not running every 5 minutes like I have it set to.
Is this the first time you’ve seen this error? (N):
- Change it to Cron in Settings>Basic Settings instead of Ajax
- Switch it back to Ajax after the Cron job does not run in 5 minutes
- Manually run Cron Job to complete and move it back to Cron Job to see if it will work and it does not.
Error core Tried to log in Scott but could not verify token 2022-11-14T10:33:31-0500
Error core Tried to log in Scott but could not verify token 2022-11-14T10:33:30-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-12T16:46:28-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-12T16:46:27-0500
Error PHP Error: dns_get_record(): A temporary server error occurred. at /var/www/cloud.experiencedmg.net/lib/private/Http/Client/DnsPinMiddleware.php#83 2022-11-11T13:39:40-0500
Error PHP Error: dns_get_record(): A temporary server error occurred. at /var/www/cloud.experiencedmg.net/lib/private/Http/Client/DnsPinMiddleware.php#83 2022-11-11T13:39:21-0500
Error PHP Error: dns_get_record(): A temporary server error occurred. at /var/www/cloud.experiencedmg.net/lib/private/Http/Client/DnsPinMiddleware.php#83 2022-11-11T13:39:18-0500
Error PHP Error: dns_get_record(): A temporary server error occurred. at /var/www/cloud.experiencedmg.net/lib/private/Http/Client/DnsPinMiddleware.php#83 2022-11-11T13:38:58-0500
Error no app in context OCP\AppFramework\QueryException: Could not resolve logger! Class "logger" does not exist 2022-11-11T11:12:34-0500
Error no app in context OCP\AppFramework\QueryException: Could not resolve logger! Class "logger" does not exist 2022-11-11T11:11:50-0500
Error no app in context OCP\AppFramework\QueryException: Could not resolve logger! Class "logger" does not exist 2022-11-11T11:11:24-0500
Error no app in context OCP\AppFramework\QueryException: Could not resolve logger! Class "logger" does not exist 2022-11-11T11:11:17-0500
Error no app in context OCP\AppFramework\QueryException: Could not resolve logger! Class "logger" does not exist 2022-11-11T11:10:13-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:32:54-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:32:51-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:32:49-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:32:39-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:32:37-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:30:37-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:30:36-0500
Error PHP Error: fseek(): Stream does not support seeking at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#46 2022-11-11T10:30:34-0500
Error core Tried to log in Scott but could not verify token 2022-11-10T08:36:15-0500
Error index Icewind\SMB\Exception\Exception: Malformed state response from server 2022-11-09T16:34:48-0500
Error PHP Error: Undefined array key "attributes" at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/smb/src/Wrapped/Parser.php#155 2022-11-09T16:34:48-0500
Error index Icewind\SMB\Exception\Exception: Malformed state response from server 2022-11-09T16:34:46-0500
Error PHP Error: Undefined array key "attributes" at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/smb/src/Wrapped/Parser.php#155 2022-11-09T16:34:46-0500
Error index Icewind\SMB\Exception\Exception: Malformed state response from server 2022-11-09T16:34:43-0500
Error PHP Error: Undefined array key "attributes" at /var/www/cloud.experiencedmg.net/apps/files_external/3rdparty/icewind/smb/src/Wrapped/Parser.php#155 2022-11-09T16:34:43-0500
Error index Icewind\SMB\Exception\Exception: Malformed state response from server 2022-11-09T15:26:45-0500
PASTE HERE
192.168.1.177 - - [14/Nov/2022:16:20:51 +0000] "GET /ocs/v2.php/apps/notificati>
192.168.1.177 - Scott [14/Nov/2022:16:20:55 +0000] "PROPFIND /remote.php/dav/fi>
192.168.1.177 - - [14/Nov/2022:16:20:51 +0000] "GET /index.php/apps/logreader/p>
192.168.1.177 - - [14/Nov/2022:16:21:21 +0000] "GET /ocs/v2.php/apps/notificati>
192.168.1.177 - Scott [14/Nov/2022:16:21:25 +0000] "GET /ocs/v2.php/apps/user_s>
192.168.1.177 - Scott [14/Nov/2022:16:21:25 +0000] "PROPFIND /remote.php/dav/fi>
192.168.1.177 - Scott [14/Nov/2022:16:21:25 +0000] "GET /ocs/v2.php/apps/notifi>
192.168.1.177 - - [14/Nov/2022:16:21:11 +0000] "GET /index.php/apps/logreader/p>
192.168.1.177 - - [14/Nov/2022:16:21:31 +0000] "GET /index.php/apps/logreader/p>
192.168.1.177 - - [14/Nov/2022:16:21:51 +0000] "GET /ocs/v2.php/apps/notificati>
192.168.1.177 - Scott [14/Nov/2022:16:21:55 +0000] "PROPFIND /remote.php/dav/fi>
192.168.1.177 - - [14/Nov/2022:16:21:51 +0000] "GET /index.php/apps/logreader/p>
192.168.1.177 - - [14/Nov/2022:16:22:21 +0000] "GET /ocs/v2.php/apps/notificati>
192.168.1.177 - Scott [14/Nov/2022:16:22:25 +0000] "GET /ocs/v2.php/apps/notifi>
192.168.1.177 - Scott [14/Nov/2022:16:22:25 +0000] "PROPFIND /remote.php/dav/fi>
192.168.1.177 - Scott [14/Nov/2022:16:22:25 +0000] "GET /ocs/v2.php/apps/user_s>
192.168.1.177 - - [14/Nov/2022:16:22:11 +0000] "GET /index.php/apps/logreader/p>
192.168.1.177 - - [14/Nov/2022:16:22:51 +0000] "GET /ocs/v2.php/apps/notificati>
<ader/poll?lastReqId=6hovnBZwx8cmXKK4sfwZ HTTP/1.1" 200 220 22
PASTE HERE
Putting my Config for cron jobs:
*/5 * * * * php -f /var/www/cloud.experiencedmg.net/cron.php
This is in the crontab -u www-data -e output. It was entered in the crontab -u www-data -l command.
