Cron job hanging and possible work-arounds
    • Nextcloud Hub 26 Spring (34.0.0)
    • Debian 13.5 (trixie)
    • apache2 2.4.67-1~deb13u3
    • None
    • PHP 8.4.21 (cli) (built: May 8 2026 05:56:48) (NTS)
    • Not sure. Say at least since April, 2026
    • Zip file download, and updates since.
From time to time, the cron job (cron.php) hangs, sometimes for a day or more before I discover it. I do not have a diagnosis or solution, but I do have two possible workarounds.
I have no idea, sorry. Possibly rebooting, which I have been doing a lot for unrelated reasons, but I have not tested this hypothesis.
root@hawk:/var/local/nc.data# su www-data -c 'php -f /var/www/nextcloud/occ config:list system; echo $?'
            "nextcloud",
            "nextcloud.localdomain",
            "localhost",
            "hawk",
            "hawk.localdomain",
            "nextcloud.curleynet.mywire.org:17800"
        "dbtype": "sqlite3",
        "version": "34.0.0.12",
        "overwrite.cli.url": "http:\/\/localhost",
        "default_phone_region": "US",
        "theme": "",
        "loglevel": 2,
        "logtimezone": "America\/Denver",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": true,
        "mail_smtpauthtype": "LOGIN",
        "app_install_overwrite": [
            "calendar"
        "trashbin_retention_obligation": "auto, 90",
        "maintenance_window_start": 19,
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 1.5
        "versions_retention_obligation": "auto, 90",
        "data-fingerprint": "8fbb403d5754a1b6bf96b34cabc08a6b",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": false,
                "verify_peer": true,
                "verify_peer_name": true
0
root@hawk:/var/local/nc.data# su www-data -c 'php -f /var/www/nextcloud/occ app:list; echo $?'
  - activity: 7.0.0
  - app_api: 34.0.0
  - appstore: 1.0.0
  - bruteforcesettings: 7.0.0
  - calendar: 6.5.0
  - circles: 34.0.0
  - cloud_federation_api: 1.18.0
  - comments: 1.24.0
  - contacts: 8.7.1
  - contactsinteraction: 1.15.0
  - dashboard: 7.14.0
  - dav: 1.39.0
  - federatedfilesharing: 1.24.0
  - federation: 1.24.0
  - files: 2.6.0
  - files_downloadlimit: 5.2.0-dev.0
  - files_external: 1.26.0
  - files_lock: 34.0.0
  - files_pdfviewer: 7.0.0-dev.0
  - files_reminders: 1.7.0
  - files_sharing: 1.26.0
  - files_trashbin: 1.24.0
  - files_versions: 1.27.0
  - firstrunwizard: 7.0.0-dev.0
  - logreader: 7.0.0
  - lookup_server_connector: 1.22.0
  - nextcloud_announcements: 6.0.0
  - notes: 6.0.0
  - notifications: 7.0.0-dev.1
  - oauth2: 1.22.0
  - office: 1.0.0
  - password_policy: 6.0.0-dev.0
  - privacy: 6.0.0-dev.1
  - profile: 1.3.0
  - provisioning_api: 1.24.0
  - recommendations: 7.0.0-dev.0
  - related_resources: 5.0.0-dev.0
  - serverinfo: 6.0.0
  - settings: 1.17.0
  - sharebymail: 1.24.0
  - support: 6.0.0
  - suspicious_login: 12.0.0-dev.0
  - systemtags: 1.24.0
  - tables: 2.2.0
  - text: 8.0.0
  - theming: 2.9.0
  - twofactor_backupcodes: 1.23.0
  - twofactor_totp: 16.0.0
  - updatenotification: 1.24.0
  - user_status: 1.14.0
  - viewer: 7.0.0-dev.0
  - webhook_listeners: 1.6.0
  - workflowengine: 2.16.0
  - admin_audit: 1.24.0
  - encryption: 2.22.0
  - photos: 7.0.0 (installed 2.0.1)
  - survey_client: 6.0.0-dev.0 (installed 2.0.0)
  - testing: 1.23.0
  - twofactor_nextcloud_notification: 8.0.0
  - user_ldap: 1.25.0
  - weather_status: 1.14.0 (installed 1.2.0)
0
The cron job hangs, sometimes for as much as a day. It may be associated with rebooting, which I have been doing a lot lately for unrelated reasons. I do not have a solution, but I have two possible workarounds.
  1. I originally got my nextcloudcron.service from an earlier version of the manual, version 28 I believe. The current version has a line the earlier version does not have, specifically the ExecCondition line. https://docs.nextcloud.com/server/stable/admin_manual/configuration_server/background_jobs_configuration.html#systemd Inserting that line may help the problem.
  2. Use timeout to limit the life of a given instance. My ExecStart line now looks like so:
ExecStart=timeout -p 12m /usr/bin/php -f /var/www/nextcloud/cron.php
The 12 minute timeout is very generous on my system as it is a small system. It allows for up to two skipped runs.
I have not done extensive testing, but one or both of these seems to work so far.
out of curiosity: Why don’t you use cronjob?
occ status --help says:
-e, --exit-code        exit with 0 if running in normal mode, 1 when in maintenance mode, 2 when `./occ upgrade` is needed. Does not write any output to STDOUT.
So, this line basically this checks the exit code of the occ status command, and only runs the cronjob if the exit code is 0 which prevents the cron job from running when, for example, Nextcloud is in maintenance mode or an upgrade is pending.
That said, I don’t think it will help much if a background job is actually hanging or otherwise causing problems.
Hmm, I’m not entirely sure about the implications of that, but I’d say it’s more of a nasty workaround than an actual solution.
After all, you’re simply terminating the process after 12 minutes. That obviously helps in the sense that cron.php can be started again afterwards, but it doesn’t really address the underlying issue.
It would probably be better to find out why cron.php is hanging in the first place, or more specifically, which background job started by cron.php is causing the problem.
Maybe occ background-job:history could help pinpoint the issue. You can also list all registered background jobs and run them individually, which might help identify the job that is causing the problem:
 background-job
  background-job:delete                  Remove a background job from database
  background-job:execute                 Execute a single background job manually
  background-job:history                 Show currently running jobs
  background-job:list                    List background jobs
  background-job:running                 Show currently running jobs
  background-job:worker                  Run a background job worker
If there is a program called “cronjob”, I’m not aware of it.
If you mean, “Why don’t I use a cron job”, Debian is a systemd distribution. Under systemd, cron is a front end for systemd’s timers and services. Using a cron job would add an unnecessary layer.
I agree. This line helps prevent the problem of launching a cron job when the system is still coming up, or in maintenance mode, and not ready for it to run, causing the hangup.
I quite agree. Which is why I titled the post in part “possible work-arounds”.
There’s even a website for it!
Thanks, but I’ll pass. I’ve been writing my own cron jobs for decades, and see no reason to do remotely what I can do perfectly well locally.
