I’m trying to set up a cron job. Specifically for previewgenerator.
How do I do this?
Where are the cron files located?
Thank you.
How do I do this?
Thank you.
Usually in /var/spool/cron
Maybe you can use a webcron service called easycron.com to trigger the script to run, it very easy to set up and supports multiple configurations.
You have to add a cron job like
*/10 * * * * /var/www/html/occ preview:pre-generate
This will generate previews for new files every 10 minutes.
Make sure the right user (www-data
) runs that script.
With cron installed, you can simply use crontab -u www-data -e
to add the line.
