Nextcloud version (eg, 20.0.5): 27.0.2
Operating system and version (eg, Ubuntu 20.04): Debian 11
Apache or nginx version (eg, Apache 2.4.25): 2.4.56
PHP version (eg, 7.4): 8.2.8
I have set my instance background jobs to run in Cron, as it is recommended, but I am getting a notification in the basic settings page that says "Last job execution ran 3 hours ago. Something seems wrong. " Any help with this? If i set the Background jobs to AJAX, they seem to run fine, but there is still a notification saying "Some jobs have not been executed since 3 months ago. Please consider switching to system cron. "
- In the default settings, set the background jobs to be run by cron.
- Get error
The output of your config.php file in /var/www/nextcloud/config
'instanceid' => 'xxxxx',
'passwordsalt' => 'xxxxxxxx',
'secret' => 'xxxxxxxxx',
0 => 'xxxxxxx',
1 => 'xxxxxxx',
2 => 'xxxxxxx',
3 => 'xxxxxxx',
'datadirectory' => '/mnt/disk3/nextcloud/data',
'version' => '27.0.2.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxxxxxx',
'app_install_overwrite' =>
0 => 'occweb',
1 => 'admin_notifications',
'filesystem_check_changes' => 0,
'enforce_theme' => '',
'updater.secret' => 'xxxxxxx',
'theme' => '',
'loglevel' => 2,
'memcache.local' => '',
The output of your Apache/nginx/system log in /var/log/apache2
[Tue Aug 29 00:00:06.268484 2023] [mpm_prefork:notice] [pid 433250] AH00163: Apache/2.4.56 (Debian) OpenSSL/1.1.1n configured -- resuming normal operations
[Tue Aug 29 00:00:06.268496 2023] [core:notice] [pid 433250] AH00094: Command line: '/usr/sbin/apache2'
[Tue Aug 29 07:32:34.424814 2023] [negotiation:error] [pid 451813] [client 192.241.219.31:51768] AH00687: Negotiation: discovered file(s) matching request: /var/www/nextcloud/version (None could be negotiated).
[Tue Aug 29 11:17:32.920685 2023] [php:error] [pid 467178] [client 54.234.194.13:40542] script '/var/www/nextcloud/gate.php' not found or unable to stat
[Tue Aug 29 16:17:32.209058 2023] [php:error] [pid 485303] [client 54.226.137.151:54068] script '/var/www/nextcloud/gate.php' not found or unable to stat
