Nextcloud version : 19.0.2
Operating system and version: Linux 4.18.0-193.14.2.el8_2.x86_64 x86_64
This is a basic question regarding sharing files and folders. When I want to share a folder or file, I have to enter a name of a user or group. But whatever I try, names of users or user-groups are not recognised. So I can’t make any shares.
Have Googled for similar issues, but could only find topic regarding version 13 which were solved by updating. No updates available now, so need to find another solution.
Can someone please point me in the right direction?
Thanks for your reply, but that settings was set correct. And still I tried to use the entire usernames, groupnames, emailadresses, nothing worked.
This happened on a server which was built as a copy of another server. Now I deleted it, reinstalled nextcloud and copied the db and now everything works fine
