example
longer
example
here
Nextcloud version (eg, 20.0.5): replace me
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
I drive nextcloud/NCP on my NVIDIA Jetson Nano. I like it to use nextcloud as an OAUTH2-provider. For the communication with the clients (mainly mobile devices), I want to automate the creation of the necessary client endpoint with a shell script. I fail with the error message “CSRF check failed” or “412 Precondition Failed”.
Is this the first time you’ve seen this error? (Y/N): Yes
- start shell on nextcloud server
- execute
curl -v -u “myadmin:mypassword” https://www.mynextcloud.com/index.php/apps/oauth2/clients -d ‘{“name”:“myClient”,“redirectUri”:"$redirectUri"}’ -H “OCS-APIRequest: true” -H “Content-Type: application/json” -H “Accept: application/json”
* Expire in 4 ms for 1 (transfer 0x55b1b0bf30)
* Trying 999.999.999.999...
* TCP_NODELAY set
* Expire in 149993 ms for 3 (transfer 0x55b1b0bf30)
* Expire in 200 ms for 4 (transfer 0x55b1b0bf30)
* Connected to www.mynextcloud.com (999.999.999.999) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server did not agree to a protocol
* Server certificate:
* subject: CN=balena.io
* start date: Sep 3 00:00:00 2020 GMT
* expire date: Oct 4 12:00:00 2021 GMT
* subjectAltName: host "www.mynextcloud.com" matched cert's "*.mynextcloud.com"
* issuer: C=US; O=...; OU=Server ... 1B; CN=...
* SSL certificate verify ok.
* Server auth using Basic with user 'myadmin'
> POST /index.php/apps/oauth2/clients HTTP/1.1
> Host: www.mynextcloud.com
> Authorization: Basic secret
> User-Agent: curl/7.64.0
> X-CSRF-Token: secret
> Content-Length: 47
* upload completely sent off: 47 out of 47 bytes
< HTTP/1.1 412 Precondition Failed
< cache-control: no-cache, no-store, must-revalidate
< content-length: 31
< content-security-policy: default-src 'none';base-uri 'none';manifest-src 'self';frame-ancestors 'none'
< content-type: application/json; charset=utf-8
< date: Mon, 22 Mar 2021 07:53:58 GMT
< expires: Thu, 19 Nov 1981 08:52:00 GMT
< feature-policy: autoplay 'none';camera 'none';fullscreen 'none';geolocation 'none';microphone 'none';payment 'none'
< pragma: no-cache
< referrer-policy: no-referrer
< server: Apache
< set-cookie: oc_sessionPassphrase=lakjföldfkj; path=/nc; secure; HttpOnly; SameSite=Lax
< set-cookie: nc_sameSiteCookielax=true; path=/nc; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
< set-cookie: nc_sameSiteCookiestrict=true; path=/nc; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
< set-cookie: oc1e1awjqj0t=4su5aitgmbvtku6n6rg5js0ktm; path=/nc; secure; HttpOnly; SameSite=Lax
< set-cookie: cookie_test=test; expires=Mon, 22-Mar-2021 08:54:01 GMT; Max-Age=3600
< strict-transport-security: max-age=15552000; preload
< x-content-type-options: nosniff
< x-download-options: noopen
< x-frame-options: SAMEORIGIN
< x-permitted-cross-domain-policies: none
< x-robots-tag: none
< x-xss-protection: 1; mode=block
< connection: keep-alive
< Vary: Accept-Encoding
* Connection #0 to host www.mynextcloud.com left intact
{"message":"CSRF check failed"}
'passwordsalt' => 'secret',
'secret' => 'very secret',
0 => 'localhost',
5 => 'nextcloudpi.local',
7 => 'www.mynextcloud.com',
8 => 'nextcloudpi.lan',
1 => '172.20.0.5',
6 => 'sleep',
'datadirectory' => '/data/nextcloud/data',
'version' => '20.0.8.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'ncdbadmin',
'dbpassword' => 'veryverysecret=',
'instanceid' => 'oc1e1awjqj0t',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => 'secret',
'tempdirectory' => '/var/www/nextcloud/data/tmp',
'mail_smtpmode' => 'smtp',
'mail_from_address' => '....',
'mail_domain' => '....',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'loglevel' => 2,
'mail_smtphost' => 'smtp.....de',
'mail_smtpport' => '587',
'mail_smtpauth' => '1',
'mail_smtpsecure' => 'tls',
'mail_smtpname' => '.....de',
'mail_smtppassword' => 'secret',
'overwritewebroot' => '/nc',
'auth.bruteforce.protection.enabled' => 'false',
'csrf.disabled' => 'true',
'theme' => '',
'trusted_proxies' =>
0 => 'https://www.mynextcloud.com',
The output of your Apache log in /var/log/apache2/error.log
empty
The output of your Apache log in /var/log/apache2/other_vhosts_access.log
localhost:80 172.20.0.2 - - [21/Mar/2021:20:01:37 +0000] "POST /index.php/apps/oauth2/clients/ HTTP/1.1" 302 1657 "-" "curl/7.64.0"
