Currently, for educational purposes, I am researching on creating a Cloud storage on a cluster of Raspberry Pi 3.
To start with, I have four RPis and would like to test your idea on this small scale setup though I have not found any documentations on how to scale up ownCloud (install/setup) or (NextCloud) on RPi cluster.
Would you be kind enough and let me know if you have any documentations or guidelines that I could follow to achieve my goal.
I currently have, 4 RPis 3, NAS box and the rest of components to build a complete cluster.
I’m thinking of something similar, but as a cluster of Olimex Lime 2.
My line of thought – and I’m totally new to this whole container and cluster shebang – is that it’d make sense to run the DB on one physical node, the PHP & Nextcloud part on another one, and storage on yet another (or several).
Happy to be proven an idiot and learn more about what would actually make sense
Two years later and I just came across this. I just ordered components (Pi’s, PoE hats, a PoE switch, etc) to build such a cluster. Excited to see how this turns out!
I’ve been running a cluster using k3s on Pi 4B boards. Current cluster is 4 worker nodes, 1 master, and 1 as a NAS providing storage for PVCs. Some of my stuff is documented here: https://project.kube.thejimnicholson.com. That site runs on the cluster itself, fwiw.
I’d be very interested to see what you’ve come up with for your cluster. I found this site looking for charts/instructions on running nextcloud under kubernetes, that’s a goal of mine.
