1 can’t log in from a outside IP address , says I need to set some data …
This is behind my router , and I have port forwarded only 443 for now , ( hope this is not the problem )
I put in the allow 192.168.1.* like I have found posted no go
I can run a windows VM and log in what I put it’s local address in
2 For some strange reason , my admin password is not working any more … tried to add a dummy user , and no joy , I did add one user before with no problems at all
This is on proxmox , the build was through one of the scripts , I don’t know if something got messed up when I told it to reboot ,
So we are in test mode , so if I have to delete and rebuild not a problem at all , just don’t want to do this once I am live …
Thanks so much
