When I configure an external storage for all my users, I need to specify a path which is variable for example :
Folder Name : MyHome
External Storage : SFTP
Login credential save in session
ServerName : myserver
Root : /home/$USER
Is it possible or is there an other way to do that ?
I was just looking some info about external storage, and stopped in this old post… if you havent realized it yet, you can add $user like for ie I have an SFTP external mount with path /home/$user, and my linux users named as my nexcloud users, so $user is replaced by the user logged.
Thanks for your answer.
It would be exactly what I want to do but it doesn’t work for me.
Root : /home/$user
I don’t see any error in logfile with a loglevel 1.
using $user worked for me in nc-versions prior to 12.x.
due to several circumstances i couldn’t get it to run in 12.x and thus got away from it. so i can’t tell if it’s a bug or something else.
Thanks @JimmyKater for your answer.
My NC version is 11.0.4 but I will upgrade soon in 12.
So, do I have another solution to mount an individual SFTP share for my users ?
ummm since i got away from it some months ago, already it’s hard to remember what i did. but it just came to my mind that i needed to md (make directory) for $user manually… (since it was then on a fat32-formatted hd i didn’t need to take care about the ownership of the directory) before being able to use them…
meaning user: AbCdE had a manually made directory in /home/AbCdE
since $user-usage didn’t make the directories itself (i used it via smb)
