I could not login on my Nextcloud server per Web Interface, nobody can login,
the Loglevel is 0.
This is the message in the log-file:
I have no idea to fix this problem, webdav works fine with the owncloud-client.
I hope everybody can help me.
Thanks
Nextcloud version (11.0.3RC2):
Operating system and version (Ubuntu 14.04):
Apache version (2.4.7):
PHP version (5.6.21-1):
Is this the first time you’ve seen this error?:
No, I could not login since Dec 2016.
Can you reliably replicate it? (If so, please outline steps):
Every time
{“reqId”:“xxxxxxxxxxx”,“remoteAddr”:“xxx.xxx.xxx.xx”,“app”:“no app in context”,“message”:“Current user is not logged in”,“level”:0,“time”:“April 18, 2017 14:35:23”,“method”:“GET”,“url”:"/nextcloud/index.php/apps/files/",“user”:"–",“version”:“11.0.3.1”}
'instanceid' => 'occ___________',
'passwordsalt' => '9bc---------------------------------------------',
0 => 'www.mydomain.de',
'datadirectory' => '/var/nextcloud_data',
'version' => '11.0.3.1',
'dbname' => 'ownloud',
'dbhost' => 'localhost',
'dbuser' => 'oc_xxxxxxx',
'dbpassword' => '_________aaaaaaaa-----',
'forcessl' => true,
'theme' => '',
'log_type' => 'file',
'logfile' => '/var/nextcloud_data/nextcloud.log',
'loglevel' => 0,
'syslog_tag' => 'Nextcloud',
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
'debug' => true,
'logdateformat' => 'F d, Y H:i:s',
'cron_log' => true,
'log_rotate_size' => false,
'user_webdavauth_url' => 'https://www.mydomain.de/nextcloud/remote.php/webdav',
'secret' => '-------------------?????????????????????????????????????--------------------------',
'share_folder' => '/Shared',
'mail_smtpmode' => 'php',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.XXXXXX.de',
'mail_smtpport' => '587',
'mail_smtpname' => '____________',
'mail_smtppassword' => '???????????',
'mail_smtpsecure' => 'tls',
'mail_domain' => 'maildomain.de',
'updatechecker' => false,
'trashbin_retention_obligation' => 'auto',
'overwrite.cli.url' => '/var/www/nextcloud',
'appstore.experimental.enabled' => true,
'default_language' => 'de',
'defaultapp' => 'files',
The output of your Apache/nginx/system log in `/var/log/____`:
NO ERRORS in apache and syslog file
I had disable most APPS
- dav: 1.1.1
- federatedfilesharing: 1.1.1
- files: 1.6.1
- files_texteditor: 2.2
- lookup_server_connector: 1.0.0
- provisioning_api: 1.1.0
- twofactor_backupcodes: 1.0.0
- workflowengine: 1.1.1
- activity
- admin_audit
- comments
- encryption
- external
- federation
- files_accesscontrol
- files_automatedtagging
- files_external
- files_pdfviewer
- files_retention
- files_sharing
- files_trashbin
- files_versions
- files_videoplayer
- firstrunwizard
- gallery
- logreader
- nextcloud_announcements
- notifications
- password_policy
- serverinfo
- sharebymail
- survey_client
- systemtags
- templateeditor
- theming
- updatenotification
- user_external
- user_ldap
- user_saml
