Nextcloud version (eg, 20.0.5): 20.0.12.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04.5 LTS
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.0
PHP version (eg, 7.4): 7.2
- Login
- Wait some minutes
- Load main page
- HTTP Error 503
Only old entries not related to problem
'updatechecker' => false,
'instanceid' => 'REMOVED',
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
0 => 'cloud.t1ip.com',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'REMOVED',
'version' => '20.0.12.1',
'dbname' => 'cloud',
'dbhost' => 'localhost',
'dbuser' => 'cloud',
'dbpassword' => 'REMOVED',
'logtimezone' => 'UTC',
// 'memcache.local' => '\\OC\\Memcache\\APCu',
'memcache.local' => '\OC\Memcache\Redis',
'memcache.distributed' => '\OC\Memcache\Redis',
'redis' => [
'host' => 'localhost',
'port' => 6379,
'memcache.locking' => '\OC\Memcache\Redis',
'theme' => '',
'loglevel' => 2,
'updater.secret' => REMOVED,
'forcessl' => true,
"log_type" => "errorlog"
PHP message: [owncloud][no app in context][3] {"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve fedAuth! Class fedAuth does not exist","Code":0,"Trace":[{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["fedAuth"]},{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":96,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["fedAuth"]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":101,"function":"array_map","args":[{"__class__":"Closure"},["*** sensitive parameter replaced ***"]]},{"file":"/var/www/o
2021/08/30 16:24:02 [error] 14064#14064: *572532 FastCGI sent in stderr: "PHP message: [owncloud][no app in context][3] {"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve l! Class l does not exist","Code":0,"Trace":[{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["l"]},{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":96,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["l"]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":101,"function":"array_map","args":[{"__class__":"Closure"},[{"name":"connection","__class__":"ReflectionParameter"},{"name":"container","__class__":"ReflectionParameter"},"*** sensitive parameter replaced ***",{"name...
