I have a problem; many pages cannot load its css/js correctly as image bellow
I’m using Ubuntu 24 TLS.
This is my ngix server config
server {
listen 80;
listen [::]:80;
listen 443 quic;
listen 443 ssl;
listen [::]:443 quic;
listen [::]:443 ssl;
http2 on;
http3 off;
{{ssl_certificate_key}}
{{ssl_certificate}}
server_name nas.caoanh.dev;
{{root}}
{{nginx_access_log}}
{{nginx_error_log}}
if ($scheme != "https") {
rewrite ^ https://$host$request_uri permanent;
# set max upload size and increase upload timeout:
client_max_body_size 512M;
client_body_timeout 300s;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/wasm application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Remove X-Powered-By, which is an information leak
add_header Permissions-Policy "geolocation=(),midi=(),sync-xhr=(),microphone=(),camera=(),magnetometer=(),gyroscope=(),fullscreen=(self),payment=()";
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload;";
location ^~ /.well-known {
# The rules in this block are an adaptation of the rules
# in `.htaccess` that concern `/.well-known`.
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
# Let Nextcloud's API for `/.well-known` URIs handle all other
# requests by passing them to the front-end controller.
return 301 /index.php$request_uri;
# Remove "#" to enable the push service. Please note that this must be set up before activation.
#location /push/ {
# proxy_pass http://localhost:7867/;
# proxy_http_version 1.1;
# proxy_set_header Upgrade $http_upgrade;
# proxy_set_header Connection "Upgrade";
# proxy_set_header Host $host;
# proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
{{settings}}
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
include /etc/nginx/global_settings;
try_files $uri $uri/ /index.php?$args;
index index.php index.html;
location ~ ^\/(?:index|setup-nextcloud|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_read_timeout 3600;
fastcgi_send_timeout 3600;
fastcgi_pass 127.0.0.1:{{php_fpm_port}};
fastcgi_param PHP_VALUE "{{php_settings}}";
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
location ~ \.css\?v=[a-zA-Z0-9-]+$ {
add_header Content-Type text/css;
types {
text/javascript mjs;
location ~ \.(?:css|js|mjs|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
#add_header X-Content-Type-Options nosniff;
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
# Optional: Don't log access to other assets
access_log off;
if (-f $request_filename) {
break;
Anyone have same problem and how to fix this? Thanks
