Hi there! Iâm trying to setup a VPS with Nextcloud and Collabora in docker-compose behind a nginx reverse proxy (jwilderâs + letâs encrypt companion, not modified). I spent the day at it (learning a lotâŚ).
At this point, in the Nextcloud interface, in the Collabora Online settings, I can connect to collabora via https and using the container name: https://nextcloud-collabora:9980. However, when I open a .ods or .odt document in my nextcloud files, I get no response for:
https://nextcloud-collabora:9980/loleaflet/46545ce/loleaflet.html?WOPISrc=https%3A%2F%2Fdrive.domain.tld%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F141183_ocksbm4b6wf3&title=documentName%20-%20Copy.ods&lang=en&closebutton=1&revisionhistory=1
With Brave Browser showing the sad face sheet of paper: nextcloud-collabora âs server IP address could not be found.
To fix this, I am trying to instead put my FQDN to my Collabora server in the URL textbox (https://office.domain.tld:9980). However, I then get: Could not establish connection to the Collabora Online server.
I am at a loss here, I donât know why my nextcloud instance wonât talk to my Collabora instance over the reverse proxy. Also, when I try to reach https://office.domain.tld
, I get âOKâ displayed in the top left, which I think is normal. But when I try to reach https://office.domain.tld/loleaflet/dist/admin/admin.html,
I get a prompt that never lets me log in. The docker-compose log says:
nextcloud-collabora | wsd-00008-00046 2021-01-09 07:12:31.739516 [ websrv_poll ] WRN client - server version mismatch, disabling browser cache. Expected: 46545ce| wsd/FileServer.cpp:285 nextcloud-collabora | wsd-00008-00046 2021-01-09 07:12:31.739665 [ websrv_poll ] ERR FileServerRequestHandler::NotAuthenticated: No authentication information found| wsd/FileServer.cpp:476
nslookup office.domain.tls
returns the external (WAN) IP from DNS Server 8.8.8.8
The VPS runs a Ubuntu 20.04 server with NExtcloud 20.0.2, Collabora Online app 3.7.11, Collabora server 6.4.3.1 (latest).
Here is my docker-compose.yml:
version: â3.8â
volumes:
nextcloud:
nextcloud-db:
services:
nextcloud-db:
image: postgres:13.1
container_name: "nextcloud-db"
restart: always
volumes:
- "./nextcloud-db:/var/lib/postgresql/data"
environment:
- POSTGRES_ROOT_PASSWORD=${ROOT_PASSWORD}
- POSTGRES_PASSWORD=${APP_PASSWORD}
- POSTGRES_DB=nextcloud
- POSTGRES_USER=${USERNAME}
nextcloud:
image: nextcloud:20.0.2-fpm
container_name: "nextcloud"
links:
- nextcloud-db
volumes:
- "./nextcloud:/var/www/html"
restart: always
environment:
- POSTGRES_HOST=nextcloud-db
web:
build: ./web
container_name: "nextcloud-web"
restart: always
volumes:
- "./nextcloud:/var/www/html:ro"
- "../reverse-proxy/certs/office.${DOMAIN}:/etc/nginx/certs:ro"
environment:
- VIRTUAL_HOST=drive.${DOMAIN}
- LETSENCRYPT_HOST=drive.${DOMAIN}
- LETSENCRYPT_EMAIL=${USERNAME}@${DOMAIN}
depends_on:
- nextcloud
networks:
- network-proxy
- default
collabora:
image: collabora/code
container_name: "nextcloud-collabora"
networks:
- default
- network-proxy
ports:
- 9980:9980
depends_on:
- web
cap_add:
- MKNOD
environment:
- username=admin
- password=${APP_PASSWORD}
# Domain the service should be accessed from:
- domain=drive\.${DOMAIN}
- DONT_GEN_SSL_CERT="True"
- VIRTUAL_PROTO=https
- VIRTUAL_PORT=443
- VIRTUAL_HOST=office.${DOMAIN}
- LETSENCRYPT_HOST=office.${DOMAIN}
# Extra parameters to Collabora, see also
# https://www.collaboraoffice.com/code/nginx-reverse-proxy/:
# SSL terminates at the proxy
- extra_params=--o:ssl.enable=true
- TZ=America/Toronto
volumes:
- "/etc/timezone:/etc/timezone"
- "/etc/localtime:/etc/localtime"
- "../reverse-proxy/certs/office.${DOMAIN}/key.pem:/etc/loolwsd/key.pem:ro"
- "../reverse-proxy/certs/office.${DOMAIN}/cert.pem:/etc/loolwsd/cert.pem:ro"
- "../reverse-proxy/certs/office.${DOMAIN}/chain.pem:/etc/loolwsd/ca-chain.cert.pem:ro"
coturn:
image: instrumentisto/coturn
container_name: nextcloud-coturn
restart: unless-stopped
ports:
- "3478:3478/tcp"
- "3478:3478/udp"
command:
- -n
- --log-file=stdout
- --min-port=49160
- --max-port=49200
- --realm=drive.${DOMAIN}
- --use-auth-secret
- --static-auth-secret=${APP_PASSWORD}
networks:
network-proxy:
external: true
Here is nginx.conf, used by the web
service. It has a 2nd server block for Collabora, which Iâm not sure is needed, taken from here: https://www.collaboraoffice.com/code/nginx-reverse-proxy/
. I use a script to copy/paste the config, thatâs why there is a â\â before every â$â
worker_processes auto;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '\$remote_addr - \$remote_user [\$time_local] "\$request" '
'\$status \$body_bytes_sent "\$http_referer" '
'"\$http_user_agent" "\$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
keepalive_timeout 65;
set_real_ip_from 10.0.0.0/8;
set_real_ip_from 172.16.0.0/12;
set_real_ip_from 192.168.0.0/16;
real_ip_header X-Real-IP;
#gzip on;
upstream php-handler {
server nextcloud:9000;
server {
listen 80;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDOMAINs; preload;" always;
# will add the DOMAIN to a hardcoded list that is shipped
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-DOMAIN-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/html;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 \$scheme://\$host:\$server_port/remote.php/dav;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-DOMAIN-policy;
#pagespeed off;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy)\.php(?:\$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)\$;
set \$path_info \$fastcgi_path_info;
try_files \$fastcgi_script_name =404;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME \$document_root\$fastcgi_script_name;
fastcgi_param PATH_INFO \$path_info;
# fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ^~ /hosting/capabilities {
proxy_pass https://127.0.0.1:9980;
proxy_set_header Host \$http_host;
location ~ ^\/(?:updater|oc[ms]-provider)(?:\$|\/) {
try_files \$uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)\$ {
try_files \$uri /index.php\$request_uri;
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)\$ {
# Optional: Don't log access to other assets
access_log off;
server {
listen 443 ssl;
server_name office.${DOMAIN};
ssl_certificate /etc/nginx/certs/cert.pem;
ssl_certificate_key /etc/nginx/certs/key.pem;
# static files
location ^~ /loleaflet {
proxy_pass https://localhost:9980;
# WOPI discovery URL
location ^~ /hosting/discovery {
# Capabilities
# main websocket
location ~ ^/lool/(.*)/ws\$ {
proxy_set_header Upgrade \$http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_read_timeout 36000s;
# download, presentation and image upload
location ~ ^/lool {
# Admin Console websocket
location ^~ /lool/adminws {
And here is Nextcloudâs config.php:
<?php $CONFIG = array ( 'memcache.local' => '\\OC\\Memcache\\APCu', 'apps_paths' => array ( 0 => array ( 'path' => '/var/www/html/apps', 'url' => '/apps', 'writable' => false, ), 1 => array ( 'path' => '/var/www/html/custom_apps', 'url' => '/custom_apps', 'writable' => true, ), ), 'instanceid' => 'asdasdasdasd', 'passwordsalt' => 'asdasdasdasdasd', 'secret' => 'asdasdasdasdasd', 'trusted_domains' => array ( 0 => 'drive.domain.tld', ), 'datadirectory' => '/var/www/html/data', 'dbtype' => 'pgsql', 'version' => '20.0.2.2', 'overwrite.cli.url' => 'http://drive.domain.tld', 'dbname' => 'nextcloud', 'dbhost' => 'nextcloud-db', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'oc_admin', 'dbpassword' => 'asdasdasdasd', 'installed' => true, 'overwritehost' => 'drive.domain.tld', 'overwriteprotocol' => 'https', 'maintenance' => false, );
I have not added anything to my hosts file. I think that covers the information I have.
