Recently my log file fills quickly (twich per minute) with the following error:
[{“file”:“/var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php”,“line”:154,“function”:“checkAndEnableCODEServer”,“class”:“OCA\Richdocuments\AppInfo\Application”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php”,“line”:200,“function”:“boot”,“class”:“OCA\Richdocuments\AppInfo\Application”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/App/AppManager.php”,“line”:434,“function”:“bootApp”,“class”:“OC\AppFramework\Bootstrap\Coordinator”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/App/AppManager.php”,“line”:213,“function”:“loadApp”,“class”:“OC\App\AppManager”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/private/legacy/OC_App.php”,“line”:125,“function”:“loadApps”,“class”:“OC\App\AppManager”,“type”:“->”},{“file”:“/var/www/nextcloud/lib/base.php”,“line”:1049,“function”:“loadApps”,“class”:“OC_App”,“type”:“::”},{“file”:“/var/www/nextcloud/index.php”,“line”:39,“function”:“handleRequest”,“class”:“OC”,“type”:“::”}],“File”:“/var/www/nextcloud/apps/richdocuments/lib/AppInfo/Application.php”,“Line”:226,“message”:“Could not boot richdocuments: Call to undefined method OCA\Richdocuments\Service\DiscoveryService::refetch()”,“exception”:{},“CustomMessage”:“Could not boot richdocuments: Call to undefined method OCA\Richdocuments\Service\DiscoveryService::refetch()”}}
Nextcloud version (eg, 20.0.5): 28.0.1 (Hansson)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.6 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): 8.1.27
The issue you are facing: The above log error repeteadly - alså without logged in users.
All ideas are appreciated - thank you
