- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
33.0.3 AIO 13.0.4
Truenas25.10.3.1
replace me
replace me
- PHP version (e.g, 8.3):
replace me
replace me
replace me
AIO
Cloudflare only for externa access.
Environment: Nextcloud AIO on TrueNAS SCALE, Context Chat + context_chat_backend 5.3.0.
Background jobs are set to Cron and are running via:
docker exec -u www-data nextcloud-aio-nextcloud php -f /var/www/html/cron.php every 2 minutes.
Context Chat shows:
Total eligible files: 10407
Files in indexing queue: 3702 (3700 new)
Files successfully sent to backend: 6063
Indexed documents: files__default => 9538, mail__mail => 8355
mail__mail keeps increasing, but files__default barely moves.
occ background-job:list shows:
OCA\ContextChat\BackgroundJobs\IndexerJob with recent last_run
OCA\ContextChat\BackgroundJobs\FileSystemListenerJob and ActionJob with recent last_run
OCA\ContextChat\BackgroundJobs\SubmitContentJob with last_run = 1970-01-01T00:00:00+00:00
When I force the job with:
php occ background-job:execute 86753023916453888
it prints “Job executed!”, but running occ context_chat:stats afterwards shows no change in “Files successfully sent to backend” or files__default.
At the same time, the Mail app has:
“Make mails available to Context Chat” disabled in the user settings,
but mail__mail continues to be indexed and there are active OCA\Mail\BackgroundJob\ContextChat… jobs with recent last_run.
This looks like:
Context Chat’s SubmitContentJob for files not processing the file queue at all, and
the Mail → Context Chat integration not respecting the “Make mails available to Context Chat” toggle.
{ "system": { "one-click-instance": true, "one-click-instance.user-limit": 100, "memcache.local": "\\OC\\Memcache\\APCu", "apps_paths": [ { "path": "\/var\/www\/html\/apps", "url": "\/apps", "writable": false }, { "path": "\/var\/www\/html\/custom_apps", "url": "\/custom_apps", "writable": true } ], "check_data_directory_permissions": false, "memcache.distributed": "\\OC\\Memcache\\Redis", "memcache.locking": "\\OC\\Memcache\\Redis", "redis": { "host": "***REMOVED SENSITIVE VALUE***", "password": "***REMOVED SENSITIVE VALUE***", "port": 6379, "timeout": 3, "read_timeout": 10 }, "overwritehost": "nextcloud.enghult.se", "overwriteprotocol": "https", "passwordsalt": "***REMOVED SENSITIVE VALUE***", "secret": "***REMOVED SENSITIVE VALUE***", "trusted_domains": [ "localhost", "nextcloud.enghult.se", "127.0.0.1", "172.16.1.6", "192.168.1.37" ], "datadirectory": "***REMOVED SENSITIVE VALUE***", "dbtype": "pgsql", "version": "33.0.3.2", "overwrite.cli.url": "https:\/\/nextcloud.enghult.se\/", "dbname": "***REMOVED SENSITIVE VALUE***", "dbhost": "***REMOVED SENSITIVE VALUE***", "dbport": "", "dbtableprefix": "oc_", "dbuser": "***REMOVED SENSITIVE VALUE***", "dbpassword": "***REMOVED SENSITIVE VALUE***", "installed": true, "instanceid": "***REMOVED SENSITIVE VALUE***", "maintenance": false, "loglevel": 2, "log_type": "file", "logfile": "\/var\/www\/html\/data\/nextcloud.log", "log_rotate_size": 10485760, "log.condition": { "apps": [ "admin_audit" ] }, "preview_max_x": 2048, "preview_max_y": 2048, "jpeg_quality": 60, "enabledPreviewProviders": { "0": "OC\\Preview\\Imaginary", "1": "OC\\Preview\\ImaginaryPDF", "2": "OC\\Preview\\ImaginaryPDF", "3": "OC\\Preview\\ImaginaryPDF", "4": "OC\\Preview\\ImaginaryPDF", "5": "OC\\Preview\\Movie", "6": "OC\\Preview\\ImaginaryPDF", "7": "OC\\Preview\\ImaginaryPDF", "8": "OC\\Preview\\ImaginaryPDF", "9": "OC\\Preview\\HEIC", "10": "OC\\Preview\\ImaginaryPDF", "11": "OC\\Preview\\TIFF", "12": "OC\\Preview\\ImaginaryPDF", "13": "OC\\Preview\\ImaginaryPDF", "14": "OC\\Preview\\Image", "23": "OC\\Preview\\ImaginaryPDF" }, "enable_previews": true, "upgrade.disable-web": true, "mail_smtpmode": "smtp", "trashbin_retention_obligation": "auto, 30", "versions_retention_obligation": "auto, 30", "activity_expire_days": 30, "simpleSignUpLink.shown": false, "share_folder": "\/Shared", "one-click-instance.link": "https:\/\/nextcloud.com\/all-in-one\/", "upgrade.cli-upgrade-link": "https:\/\/github.com\/nextcloud\/all-in-one\/discussions\/2726", "updatedirectory": "\/nc-updater", "maintenance_window_start": 100, "allow_local_remote_servers": true, "davstorage.request_timeout": 3600, "documentation_url.server_logs": "https:\/\/github.com\/nextcloud\/all-in-one\/discussions\/5425", "htaccess.RewriteBase": "\/", "dbpersistent": false, "auth.bruteforce.protection.enabled": true, "ratelimit.protection.enabled": true, "files_external_allow_create_new_local": true, "trusted_proxies": "***REMOVED SENSITIVE VALUE***", "preview_imaginary_url": "***REMOVED SENSITIVE VALUE***", "preview_imaginary_key": "***REMOVED SENSITIVE VALUE***", "memories.db.triggers.fcu": true, "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-musl", "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64", "memories.vod.ffmpeg": "\/usr\/bin\/ffmpeg", "memories.vod.ffprobe": "\/usr\/bin\/ffprobe", "default_phone_region": "SE", "mail_sendmailmode": "smtp", "mail_from_address": "***REMOVED SENSITIVE VALUE***", "mail_domain": "***REMOVED SENSITIVE VALUE***", "mail_smtphost": "***REMOVED SENSITIVE VALUE***", "mail_smtpport": "465", "mail_smtpauth": 1, "mail_smtpname": "***REMOVED SENSITIVE VALUE***", "mail_smtppassword": "***REMOVED SENSITIVE VALUE***", "memories.gis_type": 2, "updater.release.channel": "stable", "updatechecker": false, "data-fingerprint": "3a7b7fb10445bdab7085cdaf526a7648", "facerecognition.external_model_url": "nextcloud-aio-facerecognition:5000", "facerecognition.external_model_api_key": "***REMOVED SENSITIVE VALUE***", "enabledFaceRecognitionMimetype": [ "image\/jpeg", "image\/png", "image\/heic", "image\/tiff", "image\/webp" ], "memories.vod.disable": false, "memories.vod.external": true, "memories.vod.connect": "nextcloud-aio-memories:47788", "serverid": 473, "log_type_audit": "file", "logfile_audit": "\/var\/www\/html\/data\/audit.log", "app_install_overwrite": [ "occweb" ], "DOMAIN": "nextcloud.enghult.se", "AIO_VERSION": "v13.0.4" }}
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
