Context Agent is not usable
    • 31
    • Ubuntu 24.04
    • Apache2
    • 8.3
    • Yes
    • after install
    • local
    • no
I have the Context Agent installed, the Docker container is running.
In the settings, the Context Agent is set:
However, I can’t access it anywhere. Where can I query the Context Agent by terms or tasks? In AI Assistant - Context Chat, I can only select “Files” as a provider.
  1. Install AI components as in NC Admin Docs given
  2. Install context_agent
  3. Nextcloud Assistant didn’t offer a Context Agent to search for Mail, Task, or Appointments.
No errors in any log I checked (nextcloud.log, journal)
            "XXXXX",
            "127.0.0.1",
            "XXXXX",
            "localhost"
        "overwritewebroot": "\/XXXXX",
        "overwrite.cli.url": "https:\/\/XXXXXX\/XXXXX",
        "dbtype": "pgsql",
        "version": "31.0.0.18",
        "dbport": "",
        "app.mail.verify-tls-peer": false,
        "mail_smtpmode": "sendmail",
        "mail_smtpauthtype": "LOGIN",
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "dbindex": 0,
            "timeout": 1.5
        "theme": "",
        "loglevel": 2,
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "mysql.utf8mb4": true,
        "clear_site_data": true,
        "mail_sendmailmode": "smtp",
        "app_install_overwrite": {
            "0": "ocr",
            "1": "files_ebookreader",
            "2": "epubreader",
            "3": "dicomviewer",
            "4": "mindmap_app",
            "5": "fulltextsearch",
            "6": "fulltextsearch_elasticsearch",
            "7": "files_fulltextsearch",
            "8": "files_fulltextsearch_tesseract",
            "9": "riotchat",
            "10": "ojsxc",
            "11": "extract",
            "12": "memories",
            "13": "music",
            "14": "files_rightclick",
            "15": "metadata",
            "16": "talk_matterbridge",
            "17": "files_archive",
            "18": "cfg_share_links",
            "20": "tasks",
            "21": "occweb",
            "22": "radio",
            "23": "files_antivirus",
            "24": "side_menu",
            "25": "duplicatefinder",
            "26": "epubviewer",
            "27": "maps",
            "28": "electronicsignatures",
            "29": "intros",
            "30": "thesearchpage",
            "31": "timemanager",
            "32": "uppush"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "default_phone_region": "DE",
        "enable_previews": true,
        "session_relaxed_expiry": true,
        "memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "versions_retention_obligation": "auto, 180",
        "activity_expire_days": 365,
        "data-fingerprint": "2f550edebc0aa062e8c84b74fddcb9bc",
        "auth.webauthn.enabled": true
  • activity: 4.0.0
  • app_api: 5.0.2
  • assistant: 2.4.0
  • calendar: 5.1.2
  • cfg_share_links: 6.1.1
  • circles: 31.0.0-dev.0
  • contacts: 7.0.3
  • contactsinteraction: 1.12.0
  • context_chat: 4.1.0
  • dashboard: 7.11.0
  • dav: 1.33.0
  • deck: 1.15.0
  • dicomviewer: 2.3.0
  • drop_account: 2.7.1
  • eidlogin: 1.0.18
  • epubviewer: 1.7.3
  • extract: 1.3.6
  • federation: 1.21.0
  • files: 2.3.1
  • files_antivirus: 6.0.0
  • files_archive: 1.2.3
  • files_automatedtagging: 2.0.0
  • files_downloadlimit: 4.0.0
  • files_emailviewer: 0.1.4
  • files_external: 1.23.0
  • files_fulltextsearch: 31.0.0
  • files_fulltextsearch_tesseract: 27.0.1
  • files_mindmap: 0.0.33
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • files_zip: 2.1.0
  • fileslibreofficeedit: 2.0.1
  • firstrunwizard: 4.0.0
  • flow_notifications: 2.0.0
  • fulltextsearch: 31.0.0
  • fulltextsearch_elasticsearch: 31.0.0
  • gpoddersync: 3.12.0
  • gpxpod: 7.0.4
  • integration_openai: 3.4.0
  • intros: 1.0.2
  • libresign: 11.0.3
  • logreader: 4.0.0
  • mail: 4.2.3
  • maps: 1.5.0
  • memories: 7.5.2
  • metadata: 0.21.0
  • notes: 4.11.0
  • notifications: 4.0.0
  • notify_push: 1.0.0
  • oauth2: 1.19.1
  • occweb: 0.2.2
  • ownershiptransfer: 1.1.0
  • passwords: 2025.2.20
  • photos: 4.0.0-dev.1
  • polls: 7.3.2
  • previewgenerator: 5.8.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • radio: 1.0.3
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • repod: 3.5.6
  • richdocuments: 8.6.2
  • riotchat: 0.18.7
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • side_menu: 4.0.1
  • snowflakestheme: 1.1.3
  • spreed: 21.0.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • talk_matterbridge: 1.31.1026000
  • tasks: 0.16.1
  • text: 5.0.0
  • theming: 2.6.1
  • thesearchpage: 1.2.8
  • timemanager: 0.3.17
  • twofactor_webauthn: 2.1.0
  • unroundedcorners: 1.1.4
  • updatenotification: 1.21.0
  • uppush: 2.3.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • welcome: 1.2.1
  • workflow_ocr: 1.31.0
  • workflow_script: 2.0.0
  • workflowengine: 2.13.0
  • admin_audit: 1.21.0 (installed 1.8.0)
  • bruteforcesettings: 4.0.0 (installed 4.0.0)
  • comments: 1.21.0 (installed 1.3.0)
  • encryption: 2.19.0
  • files_rightclick: 0.15.1 (installed 0.15.1)
  • password_policy: 3.0.0 (installed 1.3.0)
  • snappymail: 2.38.2 (installed 2.38.2)
  • suspicious_login: 9.0.1
  • twofactor_nextcloud_notification: 5.0.0 (installed 5.0.0)
  • twofactor_totp: 13.0.0-dev.0 (installed 13.0.0-dev.0)
  • user_ldap: 1.22.0
The terminology is a little confusing, that happened to me as well. Context Chat is for chatting with your documents, if you have that enabled.
The Context Agent is used for tasks beyond files, e.g. schedule a meeting. You can access it directly in “Chat with AI”, but it only works if the AI model has the correct capabilities (in my case it only worked with qwen3:8b so far).
