Contacts will not display in Web, but DAVx5 syncing still happening on Android
    • Nextcloud Hub 10 (31.0.7)
    • Ubuntu 22.04
    • Apache version 2.4.52
    • n/a
    • n/a
    • YES
    • This month (sometime after my last monthly manual backup July 1st
    • VPS at Hostinger
    • NO
I noticed that on the web page for my Nextcloud, there are no contacts (standard Contacts App v7.2.3). If I look at the Contacts settings (bottom left corner), I see there is no address book. However, my Android phone is still syncing contacts via DAVx5, and when I make an edit to a contact on my phone, I see the change in the Nextcloud “Activities” tab as if the contacts change was properly edited on the server.
It almost seems as if the contacts database (address book) is still there, somewhere, but will not be displayed on the web due to a corruption or file problem.
I made a backup vcs file of all my contacts on android and then imported that as a new address book in Nextcloud. The import said there were 10 errors (but didn’t tell me what or how to investigate), but otherwise the import looked successful. I was able to interact and make edits on the web and the address book synced with my phone. HOWEVER, as soon as I refresh the Nextcloud Contacts web page or revisit it, all the entries and the address book are GONE!
There are no log entries related to Contacts. There are only three errors regarding the Deck.
Warning
cron
QueryNotFoundException
Could not resolve OCA\Deck\Cron\SessionsCleanup! Class “OCA\Deck\Cron\SessionsCleanup” does not exist
Jul 30, 2025, 11:01:10 AM
Warning
cron
Could not resolve OCA\Deck\Cron\CardDescriptionActivity! Class “OCA\Deck\Cron\CardDescriptionActivity” does not exist
Warning
cron
Could not resolve OCA\Deck\Cron\ScheduledNotifications! Class “OCA\Deck\Cron\ScheduledNotifications” does not exist
No older log entries available
I can repeat this behavior on two separate web browsers.
VPS at Hostinger
Your provider appears to use mod_security by default. That would be my first guess at a culprit:
Your browser inspector may still be informative.
Thank you, but mod_security was not enabled, so the problem remains.
It seems like a corrupt contact database or some type of incompatibility. If I create a new address book and manual create a simple entry. It works and persists.
Is there a way to inspect or repair the original contact database? It is obviously still stored somewhere in order for DAVx5 to connect and sync with it.
Is there a limit to the size of the address book?
I did the following:
Re-imported my backup… before refreshing the page, I exported each contact group as a file.
Then after the data auto disappears I created TWO new address books. I imported some groups to one book and the rest to the other. Seems to be working now.
