Connection WebDAV via Cyberduck didn't work anymore after current release (412 Precondition Failed)
Steps to reproduce
  1. Download latest Nextcloud All-on-one
  2. Enable 2 Factor Auth and create an app password
  3. Download latest Cyberduck Instance
  4. Configure as described here Zugriff auf Nextcloud-Dateien mit WebDAV — Nextcloud latest Benutzerhandbuch latest documentation
  5. See there is an error (412 Precondition Failed)
Expected behavior
No error and successful connection
Actual behavior
Other information
Host OS
TrueNAS Scale ElectricEel-24.10.2.1
Output of sudo docker info
Client: Docker Engine - Community
Version: 27.1.1
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.16.1
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.29.1
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
Containers: 92
Running: 83
Paused: 0
Stopped: 9
Images: 207
Server Version: 27.1.1
Storage Driver: overlay2
Backing Filesystem: zfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 2bf793ef6dc9a18e00cb12efb64355c2c9d5eb41
runc version: v1.1.13-0-g58aa920
init version: de40ad0
Security Options:
apparmor
seccomp
Profile: builtin
cgroupns
Kernel Version: 6.6.44-production+truenas
Operating System: Debian GNU/Linux 12 (bookworm)
OSType: linux
Architecture: x86_64
CPUs: 12
Total Memory: 125.2GiB
Docker Root Dir: /mnt/.ix-apps/docker
Debug Mode: false
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
Default Address Pools:
Base: 172.16.0.0/12, Size: 24
Docker run command or docker-compose file that you used
sudo docker run
–init
–sig-proxy=false
–name nextcloud-aio-mastercontainer
–restart always
–publish 8080:8080
–env APACHE_PORT=11000
–env APACHE_IP_BINDING=0.0.0.0
–env APACHE_ADDITIONAL_NETWORK=“traefik”
–env SKIP_DOMAIN_VALIDATION=false
–env NEXTCLOUD_DATADIR=“/mnt/storage-1/apps/nextcloud/user_data”
–env NEXTCLOUD_MEMORY_LIMIT=1024M
–env NEXTCLOUD_MOUNT=“/mnt/storage-1/”
–volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config
–volume /var/run/docker.sock:/var/run/docker.sock:ro
Other valuable info
Image Image
Add(change) this config option to your config.php
'csrf.optout' => [
        '/^WebDAVFS/', // OS X Finder
        '/^Microsoft-WebDAV-MiniRedir/', // Windows webdav drive
        '/^Cyberduck/', // Cyberduck
THanks I will test it, atm this error still happens. Maybe that will help
