Ok, so i’ve been using nextcloud for a while now and always complained because it works too slow for me.
Now I updated to NC12 and tried syncronization on a new machine and tested connecting using the static IP the nextcloud-server has. I tried syncing a 1GB folder and navigating through the webpage.
The result: fast web interface, (relatively) fast syncronization (~7MBps).
I then repeated the process (web browsing and syncing) using a ddns (two, actually, one from duckdns.org and the other from dedyn.io).
The result: slow login webpage, slow web.browsing, slow syncronization (between 7~26KBps).
Now I don’t know where to troubleshoot.
I thought it could be the port forwarding in the router, but since I
do load the webpage (although slowly) i’m not convinced.
I thought it could be the webserver on the nextcloud machine… I don’t get why.
Ideas?
How to troubleshoot?
I’m running NC12 stable on Lubuntu 16.04 with PHP7, Nginx and Letsencypt.
Thanks for reading!
