Some days ago the sync clients stopped to work with one server.
I have the following servers :
- A owncloud 10 with nginx
- B docker official nextcloud 13 image behind nginx reverse proxy
- C docker official nextcloud 13 image behind nginx reverse proxy
My nextcloud client is connected with the 3 servers
Everything was working some days ago and a bug occured…
The server B stopped syncronizing with my desktop and my android client, The serveur C is working on the same server with similar configuration.
On the desktop client (manjaro 18.0.3).
When i stop the mouse on the bar icon :
Nectcloud : disconnected from accounts:
Account me@B : network error
Connection timed out
The debug option on NextCloud client shows :
[OCC::FolderMan::slotAccountStateChanged Account "me@B" disconnected or paused, terminating or descheduling sync folders
The phone file app loads for a long time, and display « No file here »
But the web interface works very well, like the contacts and calendar.
- I did not upgrade anything the last days
Shoud I get my server to the next version?
There is no logs about failed connections on the container stdout.
If you know how I can troubleshoot this…
Thanks !
Edit:
The command
php occ integrity:check-core
Return an empty result
php occ maintenance:repair
Does not repair webdav
Is not checking webdav
UPDATE:
I did upgrade to version 14 then 15.
The desktop and mobile clients cant connect anymore.
- error 405 when loging in with tocken
- “access forbidden, invalid reqest” when loging in with username/password
The serveur log only shows 302 or 200 status code…
