Connection timed out when trying to access AIO behind Traefik
I’ve recently migrated to Traefik from Nginx Proxy Manager, but have been having issues accessing the AIO container behind Traefik. I’ve done my best to follow the instructions on the GitHub page (link) and these community posts (1, 2, 3, 4, 5, 6), but haven’t been able to get things set up. I’ve included my config files below. Would love some help getting this working, as I’ve been banging my head against this for a couple days now.
## nextcloud compose.yaml
services:
    init: true
    restart: unless-stopped
    ports:
      - 16001:8080
      # have also tried with the following:
      # - 16000:80
      # - 16002:8443
    volumes:
    environment:
      APACHE_PORT: 11000
      # have not tried setting APACHE_BIND_IP_ADDRESS, see provided config files in link #4
    networks:
      - proxy
volumes:
    external: true
networks:
  proxy:
    external: true
## traefik compose.yaml
services:
  traefik:
    container_name: traefik
    image: traefik:v3.1
    ports:
      - "80:80"
      - "8080:8080"
      - "443:443"
    volumes:
      - ./static.yaml:/etc/traefik/traefik.yaml
      - ./dynamic:/etc/traefik/dynamic
      - ./letsencrypt:/letsencrypt
    networks:
      - proxy
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.dashboard.rule=Host(`traefik.[my-domain].com`)"
      - "traefik.http.routers.dashboard.tls.certresolver=cloudflare"
      - "traefik.http.routers.dashboard.service=api@internal"
      - "traefik.http.routers.dashboard.middlewares=traefik_auth"
      - "traefik.http.middlewares.traefik_auth.digestauth.users=justin:traefik:[password hash]"
    environment:
      CF_DNS_API_TOKEN_FILE: /run/secrets/cf_dns_api
    secrets:
      - "cf_dns_api"
networks:
  proxy:
    external: true
secrets:
  cf_dns_api:
    file: ./secrets/cf_dns_api.secret
## traefik static.yaml
global:
  checkNewVersion: true
  sendAnonymousUsage: true
entryPoints:
  http:
    address: :80
  https:
    address: :443
log:
  level: DEBUG
api:
  insecure: false
  dashboard: true
providers:
  docker:
    # from traefik documentation
    endpoint: tcp://socket-proxy:2375
    watch: true
    exposedByDefault: false
  file:
    directory: /etc/traefik/dynamic/
    watch: true
certificatesresolvers:
  cloudflare:
    acme:
      dnschallenge:
        provider: cloudflare
      email: justin@[my-domain].com
      storage: /letsencrypt/acme.json
## nextcloud dynamic config (dynamic/nextcloud.yaml)
http:
  routers:
    nextcloud:
      rule: "Host(`cloud.[my-domain].com`)"
      entrypoints:
        - "https"
      service: nextcloud
      middlewares:
        - nextcloud-chain
      tls:
        certresolver: "cloudflare"
  services:
    nextcloud:
      loadBalancer:
        servers:
          # have tried localhost, 0.0.0.0
          - url: "http://[VPS IP]:11000" # Use the host's IP address if Traefik runs outside the host network
  middlewares:
    nextcloud-secure-headers:
      headers:
        hostsProxyHeaders:
          - "X-Forwarded-Host"
        referrerPolicy: "same-origin"
    https-redirect:
      redirectscheme:
        scheme: https
    nextcloud-chain:
      chain:
        middlewares:
          # - ... (e.g. rate limiting middleware)
          - https-redirect
          - nextcloud-secure-headers
Hi, does this video help maybe to make it work?
I’m a bit further along now, I could access the AIO interface and start all the containers, but trying to access Nextcloud from cloud.[my-domain].com gives “502 Bad Gateway”. Traefik logs say “no route to host”. I’ve added the new config files I’m using below. I’ve also lost access to the dashboard at traefik.[my-domain].com because of the changes and would like to avoid that if possible.
services:
    init: true
    ports:
      - 8080:8080
    volumes:
    environment:
      APACHE_PORT: 11000
    networks:
      - proxy
volumes:
    external: true
networks:
  proxy:
    external: true
services:
  traefik:
    image: traefik:v3.1
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - /etc/localtime:/etc/localtime:ro
    networks:
      - proxy
    labels:
      - "traefik.http.routers.dashboard.tls=true"
      - "traefik.http.routers.dashboard.tls.domains[0].main=[my-domain]"
      - "traefik.http.routers.dashboard.tls.domains[0].sans=*.[my-domain]"
    environment:
    secrets:
      - "cf_dns_api"
networks:
  proxy:
    external: true
secrets:
  cf_dns_api:
global:
entryPoints:
  http:
    address: :80
    http:
      redirections:
        entryPoint:
          to: https
          scheme: https
  https:
    address: :443
# not a fan of this
serversTransport:
  insecureSkipVerify: true
log:
  level: DEBUG
api:
  insecure: false
  dashboard: true
providers:
  docker:
    watch: true
  file:
    watch: true
  cloudflare:
    acme:
      dnschallenge:
http:
  routers:
    nextcloud:
      entrypoints:
        - "https"
      service: nextcloud
      middlewares:
        - nextcloud-chain
      tls:
        domains:
          - main: "cloud.[my-domain].com"
  services:
    nextcloud:
      loadBalancer:
        servers:
          # from hostname -I
          - url: "http://10.0.0.93:11000" # Use the host's IP address if Traefik runs outside the host network
        passHostHeader: true
  middlewares:
      headers:
        hostsProxyHeaders:
        customResponseHeaders:
          X-Robots-Tag: "none"
    https-redirect:
      redirectscheme:
        scheme: https
        permanent: true
    nextcloud-chain:
      chain:
        middlewares:
          - https-redirect
I managed to get it working by changing the dynamic config to use my VPS’ server IP (i.e., the public facing IP address for the server).
