Reproduce:
Remove a few thousand files from Nextcloud on your local machine (some GB of data), let client sync. After a minute or so nextcloud stops responding and the nginx log shows this a lot:
2016/11/09 00:22:47 [error] 2033#2033: *683 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: xxx.xxx.xxx.xxx, server: url.org, request: "GET /status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "url.org"
Restarting php7-fpm solves the problem until the client again attempts to sync.
I suspect that the reason is the new nginx version. But then I wouldn’t be sure how to fix this.
I have:
nginx 1.11.5
mysql 5.5.53
php 7.0.12
Windows 7x64
Nextcloud client
Linux mint 17.3 as the server OS
Nginx config:
fastcgi_cache_path /usr/local/tmp/cache levels=1:2 keys_zone=OWNCLOUD:100m inactive=60m;
map $request_uri $skip_cache {
default 1;
~*/thumbnail.php 0;
~*/apps/galleryplus/ 0;
~*/apps/gallery/ 0;
upstream php-handler {
#server 127.0.0.1:9000;
server unix:/var/run/php/php7.0-fpm.sock;
server {
listen 80;
server_name url.org;
# enforce https
return 301 https://$server_name$request_uri;
server {
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/url.org/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/url.org/privkey.pem;
ssl_dhparam /etc/letsencrypt/live/url.org/dhparam.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
# ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-RSA-DES-CBC3-SHA:ECDHE-ECDSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
################# collabora #######################
location ^~ /loleaflet {
add_header X-Frame-Options SAMEORIGIN;
proxy_pass https://localhost:9980;
proxy_set_header Host $http_host;
# WOPI discovery URL
location ^~ /hosting/discovery {
# websockets, download, presentation and image upload
location ^~ /lool {
proxy_set_header Connection "upgrade";
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
add_header Strict-Transport-Security "max-age=15768000;
# includeSubDomains; preload;";
add_header X-Frame-Options "SAMEORIGIN";
add_header X-Robots-Tag none;
root /var/www/nextcloud/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location = /.well-known/carddav { return 301
$scheme://$host/remote.php/dav; }
location = /.well-known/caldav { return 301
location /.well-known/acme-challenge { }
# set max upload size
client_max_body_size 10G;
fastcgi_buffer_size 1024k;
fastcgi_buffers 6536 40k;
#fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
# cache_purge (with $http_cookies we have unique keys for the user)
fastcgi_cache_key $http_cookie$request_method$host$request_uri;
fastcgi_cache_use_stale error timeout invalid_header http_500;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_read_timeout 300;
# cache_purge
fastcgi_cache_bypass $skip_cache;
fastcgi_no_cache $skip_cache;
fastcgi_cache OWNCLOUD;
fastcgi_cache_valid 60m;
fastcgi_cache_methods GET HEAD;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
# add_header Strict-Transport-Security "max-age=15768000;
access_log off;
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
Help would be appreciated.
I would open an issue but I am not sure if this is a client issue, a server issue or a documentation issue.
