Nextcloud version: 16.0.3
Operating system and version: CentOS 7.7.1908 / Docker 19.03.2
Apache or nginx version: Not sure.
PHP version: 7.3.7
Cannot access nextcloud through an nginx reverse proxy
Is this the first time you’ve seen this error? : Yes
I set up nextcloud on my docker host and had is accessible on the local network, but I cannot make it accessible from the web.
I have a docker container running the linuxserver/letsencrypt image with an nginx reverse proxy which has some other services accessible under their own subdomains. I made the recommended changes from their config files (below) to nextcloud’s configuration and now when I access it on the local IP address it redirects me to the domain and fails to load.
# assuming this container is called "letsencrypt", edit your nextcloud container's config
# located at /config/www/nextcloud/config/config.php and add the following lines before the ");":
'trusted_proxies' => ['letsencrypt'],
'overwrite.cli.url' => 'https://nextcloud.your-domain.com/',
'overwritehost' => 'nextcloud.your-domain.com',
# Also don't forget to add your domain name to the trusted domains array. It should look somewhat like this:
0 => '192.168.0.1:444', # This line may look different on your setup, don't modify it.
1 => 'nextcloud.your-domain.com',
When I try to load nextcloud.mydomain.tld my browser displays an nginx 502 bad gateway error, and the nginx log reads:
2019/10/13 14:37:41 [error] 364#364: 18 connect() failed (111: Connection refused) while connecting to upstream, client: 86.6.57.214, server: nextcloud., request: “GET / HTTP/2.0”, upstream: “https://172.18.0.7:443/”, host: “nextcloud.mydomain.tld”
Can't access
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
0 => '192.168.0.130:8082',
1 => 'nextcloud.mydomain.tld',
'version' => '17.0.0.9',
'overwrite.cli.url' => 'https://nextcloud.mydomain.tld/',
'dbname' => 'nextcloud',
'dbhost' => 'nextclouddb:3306',
'instanceid' => 'oc3gt3zfmmph',
'dbuser' => 'nextcloud',
'dbpassword' => 'REMOVED',
'theme' => '',
'loglevel' => 2,
'overwritehost' => 'nextcloud.mydomain.tld',
Docker image pipes these to /dev/stdout or /dev/stderr
