Connection refused from within nextcloud web app but works from shell
When I am trying to run
sudo -u www-data /var/www/html/nextcloud/occ vitachaos -n --path=vitachaos/files/Educational/
I am getting the following error:
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/nextcloud/lib/private/DB/Connection.php:85
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1486): OC\DB\Connection->connect()
#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1014): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/html/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(210): OC\DB\Connection->executeQuery()
#4 /var/www/html/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/html/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/html/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#7 /var/www/html/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#8 /var/www/html/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues()
#9 /var/www/html/nextcloud/lib/private/Server.php(682): OC_App::getAppVersions()
#10 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}()
#11 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#12 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#13 /var/www/html/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query()
#14 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#15 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(177): OC\AppFramework\Utility\SimpleContainer->get()
#16 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#17 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#18 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#19 /var/www/html/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query()
#20 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#21 /var/www/html/nextcloud/lib/private/Server.php(1031): OC\AppFramework\Utility\SimpleContainer->get()
#22 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}()
#23 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#24 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#25 /var/www/html/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query()
#26 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#27 /var/www/html/nextcloud/lib/private/Server.php(1990): OC\AppFramework\Utility\SimpleContainer->get()
#28 /var/www/html/nextcloud/lib/private/Files/View.php(119): OC\Server->getLockingProvider()
#29 /var/www/html/nextcloud/lib/private/Server.php(430): OC\Files\View->__construct()
#30 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}()
#31 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#32 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet()
#33 /var/www/html/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query()
#34 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#35 /var/www/html/nextcloud/lib/private/Server.php(1353): OC\AppFramework\Utility\SimpleContainer->get()
#36 /var/www/html/nextcloud/lib/base.php(588): OC\Server->boot()
#37 /var/www/html/nextcloud/lib/base.php(1076): OC::init()
#38 /var/www/html/nextcloud/console.php(49): require_once('...')
#39 /var/www/html/nextcloud/occ(11): require_once('...')
although i can login from the shell of the same host using:
mysql -u nextcloud -P 6036 -p
and it works. I am using 6036 as port address.
then I checked db accessing from root user:
>  SHOW GRANTS FOR nextcloud;
| Grants for nextcloud@%        |
| GRANT USAGE ON *.* TO 'nextcloud'@'%' IDENTIFIED BY PASSWORD '*285CACEB5CAB2A414BC5581C7F65B97C56CB8808' |
| GRANT ALL PRIVILEGES ON `nextcloud`.* TO 'nextcloud'@'%'                                                 |
2 rows in set (0.00 sec)
users:
| user      | host      | password                                  |
| nextcloud | %         | *285CACEB5CAB2A414BC5581C7F65B97C56CB8808 |
why am I getting connection refused ?
I have the same issue. Any solutions?
Without more details it’s impossible to say.
Post:
  • your config (output of occ config:list system)
  • the exact log entry or stack trace you’re seeing
Also check your nextcloud.log for clues as to when the problem started. It may help you isolate the underlying cause.
