every time i try to drag&drop a folder at my nextcloud window, i get the message “connection lost”. With files i have no problem … only if a folder is included. I am using Safari / OSX.
Is this a config issue or a bug?
Best regards!
Best regards!
Some browsers hat problems with folders in the past. I don’t know if safari supports this (or since which version). Did you try a different browser? e.g. Firefox/chrome?
