Connection from DAVX5 to NEXTCLOUD
I can not sync my smartphone with nextcloud anymore.
I deleted the account on DAVX5 then, I reinstalled it using the application nextcloud.
But, it did not work.
If anyone has an idea or a track to provide me.
Here are the logs provided by DAVX5
— BEGIN DEBUG INFO —
LOGS:
2019-08-15 09:50:28 3932 [ui.setup.DavResourceFinder] Finding initial carddav service configuration
2019-08-15 09:50:29 3932 [ui.setup.DavResourceFinder] Checking user-given URL: [Liens CLOUD]/remote.php/dav
2019-08-15 09:50:29 3932 [HttpClient] --> PROPFIND [Liens CLOUD]/remote.php/dav
2019-08-15 09:50:29 3932 [HttpClient] Content-Type: application/xml; charset=utf-8
2019-08-15 09:50:29 3932 [HttpClient] Content-Length: 290
2019-08-15 09:50:29 3932 [HttpClient] Depth: 0
2019-08-15 09:50:29 3932 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><CARD:addressbook-description /><CARD:addressbook-home-set />
2019-08-15 09:50:29 3932 [HttpClient] --> END PROPFIND (290-byte body)
2019-08-15 09:50:44 3932 [HttpClient] <-- HTTP FAILED: java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37669) after 15000ms
2019-08-15 09:50:44 3932 [ui.setup.DavResourceFinder] PROPFIND/OPTIONS on user-given URL failed
EXCEPTION java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37669) after 15000ms
at libcore.io.IoBridge.connectErrno(IoBridge.java:185)
at libcore.io.IoBridge.connect(IoBridge.java:130)
at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:129)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:356)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:356)
at java.net.Socket.connect(Socket.java:616)
at okhttp3.internal.platform.AndroidPlatform.connectSocket(AndroidPlatform.java:73)
at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:247)
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:167)
at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:258)
at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135)
at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126)
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:225)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:250)
at okhttp3.RealCall.execute(RealCall.java:93)
at at.bitfire.dav4jvm.DavResource$propfind$1.invoke(DavResource.kt:323)
at at.bitfire.dav4jvm.DavResource$propfind$1.invoke(DavResource.kt:34)
at at.bitfire.dav4jvm.DavResource.followRedirects(DavResource.kt:378)
at at.bitfire.dav4jvm.DavResource.propfind(DavResource.kt:318)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:180)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:115)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:73)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$DetectConfigurationModel$detectConfiguration$2.invoke(DetectConfigurationFragment.kt:83)
at at.bitfire.davdroid.ui.setup.DetectConfigurationFragment$DetectConfigurationModel$detectConfiguration$2.invoke(DetectConfigurationFragment.kt:62)
at kotlin.concurrent.ThreadsKt$thread$thread$1.run(Thread.kt:30)
2019-08-15 09:50:44 3932 [HttpClient] --> PROPFIND [Liens CLOUD]/.well-known/carddav
2019-08-15 09:50:44 3932 [HttpClient] Content-Type: application/xml; charset=utf-8
2019-08-15 09:50:44 3932 [HttpClient] Content-Length: 198
2019-08-15 09:50:44 3932 [HttpClient] Depth: 0
2019-08-15 09:50:44 3932 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?>
2019-08-15 09:50:44 3932 [HttpClient] --> END PROPFIND (198-byte body)
2019-08-15 09:50:59 3932 [HttpClient] <-- HTTP FAILED: java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37670) after 15000ms
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] Well-known URL detection failed
EXCEPTION java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37670) after 15000ms
at at.bitfire.davdroid.ui.setup.DavResourceFinder.getCurrentUserPrincipal(DavResourceFinder.kt:385)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:119)
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] No principal found at user-given URL, trying to discover
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] Looking up SRV records for _carddavs._tcp.cloud.zuthos!;fr
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] carddav service discovery failed
EXCEPTION java.lang.ArrayIndexOutOfBoundsException: length=0; index=0
at org.xbill.DNS.ExtendedResolver$Resolution.start(ExtendedResolver.java:102)
at org.xbill.DNS.ExtendedResolver.send(ExtendedResolver.java:358)
at org.xbill.DNS.Lookup.lookup(Lookup.java:476)
at org.xbill.DNS.Lookup.resolve(Lookup.java:528)
at org.xbill.DNS.Lookup.run(Lookup.java:542)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.discoverPrincipalUrl(DavResourceFinder.kt:331)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:138)
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] Finding initial caldav service configuration
2019-08-15 09:50:59 3932 [ui.setup.DavResourceFinder] Checking user-given URL: [Liens CLOUD]/remote.php/dav
2019-08-15 09:50:59 3932 [HttpClient] --> PROPFIND [Liens CLOUD]/remote.php/dav
2019-08-15 09:50:59 3932 [HttpClient] Content-Type: application/xml; charset=utf-8
2019-08-15 09:50:59 3932 [HttpClient] Content-Length: 435
2019-08-15 09:50:59 3932 [HttpClient] Depth: 0
2019-08-15 09:50:59 3932 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?><n0:calendar-color xmlns:n0=ā€œhttp://apple.com/ns/ical/ā€ /><CAL:calendar-description /><CAL:calendar-timezone /><CAL:supported-calendar-component-set /><CAL:calendar-home-set />
2019-08-15 09:50:59 3932 [HttpClient] --> END PROPFIND (435-byte body)
2019-08-15 09:51:14 3932 [HttpClient] <-- HTTP FAILED: java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37671) after 15000ms
2019-08-15 09:51:14 3932 [ui.setup.DavResourceFinder] PROPFIND/OPTIONS on user-given URL failed
EXCEPTION java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37671) after 15000ms
at at.bitfire.davdroid.ui.setup.DavResourceFinder.checkUserGivenURL(DavResourceFinder.kt:189)
at at.bitfire.davdroid.ui.setup.DavResourceFinder.findInitialConfiguration(DavResourceFinder.kt:80)
2019-08-15 09:51:14 3932 [HttpClient] --> PROPFIND [Liens CLOUD]/.well-known/caldav
2019-08-15 09:51:14 3932 [HttpClient] Content-Type: application/xml; charset=utf-8
2019-08-15 09:51:14 3932 [HttpClient] Content-Length: 198
2019-08-15 09:51:14 3932 [HttpClient] Depth: 0
2019-08-15 09:51:14 3932 [HttpClient] <?xml version='1.0' encoding='UTF-8' ?>
2019-08-15 09:51:14 3932 [HttpClient] --> END PROPFIND (198-byte body)
2019-08-15 09:51:29 3932 [HttpClient] <-- HTTP FAILED: java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37673) after 15000ms
2019-08-15 09:51:29 3932 [ui.setup.DavResourceFinder] Well-known URL detection failed
EXCEPTION java.net.SocketTimeoutException: failed to connect to cloud.zuthos!;fr/217.70.180.152 (port 443) from /10.1.10.1 (port 37673) after 15000ms
2019-08-15 09:51:29 3932 [ui.setup.DavResourceFinder] No principal found at user-given URL, trying to discover
2019-08-15 09:51:29 3932 [ui.setup.DavResourceFinder] Looking up SRV records for _caldavs._tcp.cloud.zuthos!;fr
2019-08-15 09:51:29 3932 [ui.setup.DavResourceFinder] caldav service discovery failed
SOFTWARE INFORMATION
  • at.bitfire.davdroid 2.5.3-ose (297) from com.google.android.packageinstaller
  • org.dmfs.tasks 1.1.20 (76000) from com.google.android.packageinstaller
  • com.android.providers.contacts 2.0.49 (204900000)
  • com.android.providers.calendar 1.0.00.35 (100000035)
  • com.samsung.android.contacts 3.8.27.1 (382700001)
  • com.simplemobiletools.contacts 5.1.1 (35) from com.google.android.packageinstaller
  • com.samsung.android.calendar 4.4.04.7 (440400007)
  • ws.xsoh.etar 1.0.17 (19) from com.google.android.packageinstaller
CONNECTIVITY (at the moment)
Active connection: mobile, CONNECTED
CONFIGURATION
Power saving disabled: yes
android.permission.READ_CONTACTS: granted
android.permission.WRITE_CONTACTS: granted
android.permission.READ_CALENDAR: granted
android.permission.WRITE_CALENDAR: granted
org.dmfs.permission.READ_TASKS: granted
org.dmfs.permission.WRITE_TASKS: granted
android.permission.ACCESS_COARSE_LOCATION: granted
System-wide synchronization: automatically
SQLITE DUMP
android_metadata
| locale |
| fr_FR |
sqlite_sequence
| name | seq |
| service | 4 |
| homeset | 15 |
| collection | 28 |
service
| id | accountName | type | principal |
homeset
| id | serviceId | url | privBind | displayName |
collection
| id | serviceId | type | url | privWriteContent | privUnbind | forceReadOnly | displayName | description | color | timezone | supportsVEVENT | supportsVTODO | supportsVJOURNAL | source | sync |
room_master_table
| id | identity_hash |
| 42 | a7554d1ebc5ecfe0c7aefe271485d63c |
SYSTEM INFORMATION
Android version: 8.0.0 (R16NW.A320FLXXU4CSD2)
Device: samsung SM-A320FL (a3y17lte)
— END DEBUG INFO —
Seems to be a connection issue from your LAN.
I do not believe. Indeed, I can connect without problem with the application NEXTCLOUD of Android
I did not understand why, but everything is back to normal
