I run NC 28.0.4 on a managed ubuntu server at all-inkl.com.
Everything worked fine since years. Since a few days (maybe since updating from 28.0.3 to 28.0.4 an 04.04.2024), some things don’t work anymore.
When I try to open a txt-File (e.g. text.txt) in my browser, I get the error message “connection failed”. When I check administrator logs, I find “JsonException Malformed UTF-8 characters, possibly incorrectly encoded”
Please share the full log entry (raw entry).
JsonException
/www/htdocs/########/nc/lib/public/AppFramework/Http/JSONResponse.php
line 71
undefinedundefinedjson_encode(
712,
“Michael”,
“#3c6eba”,
“AXAB1MubxAEGaHsidXNlciI6eyJuYW1lIjoiTWljaGFlbCIsImNsaWVudElkIjo0MTE0OTM4NDQsImNvbG9yIjoiIzNjNmViYSIsImxhc3RVcGRhdGUiOjE3MTI0MTM5MTV9LCJjdXJzb3IiOm51bGx9”,
“And 4 more entries, set log level to debug to see all entries”
811,
“Michael”,
“#3c6eba”,
null,
“OCA\Text\Db\Document”,
231556
null
4194305
/www/htdocs/########/nc/lib/private/AppFramework/Http/Dispatcher.php
line 182
OCP\AppFramework\Http\JSONResponse->render()
/www/htdocs/########/nc/lib/private/AppFramework/App.php
line 184
OC\AppFramework\Http\Dispatcher->dispatch(
“OCA\Text\Controller\SessionController”
“sync”
/www/htdocs/########/nc/lib/private/Route/Router.php
line 315
OC\AppFramework\App::main(
“OCA\Text\Controller\SessionController”,
“sync”,
“OC\AppFramework\DependencyInjection\DIContainer”
“231556”,
“text.Session.sync”
/www/htdocs/########/nc/lib/base.php
line 1069
OC\Route\Router->match(
“/apps/text/session/231556/sync”
/www/htdocs/########/nc/index.php
line 39
OC::handleRequest()
It seems that exactly one file was damaged. My local Nextcloud-Client told me, that it would not be possible, to sync this file. I copied it on my computer and deleted the old version local and on my server. Everything is fine since then. I have no clue, why this happened, but I’m happy, that Nextcloud works again.
